P-Ayr Products Replica 302 SBF Short Block Engine
Hello,
I am selling my P-Ayr 302 SBF mock up engine short block. I have come to the end of my project and no longer need it for my engine fitment. It is used, it has so me dirt and grime on it with some minor cuts and abrasions but nothing major all steel inserts are in good working condition. Please see pictures for closer inspection. If you have any question please feel free to ask. This listing is for the short block only!!!! The last picture with the bellhousing, engine mount and oil pan is for example only. P-Ayr Replica Short Blocks are designed to bolt into your car in place of your real engine for test fitting parts. They include all of the necessary mounting holes with steel threaded inserts so you can mock up your new high performance parts. P-Ayr uses steel inserts for all bolt holes, and all specifications are held to OEM tolerances. You can bolt any factory component or accessory to a P-Ayr engine and it will fit. Made from durable polyurethane foam they have steel inserts for easy mounting. Replica Block Material: Polyurethane foam Replica Block Finish: Blue Head Bolt Holes Included: Yes Intake Manifold Holes Included: No Exhaust Header Holes Included: No Oil Pan Bolt Holes Included: Yes Spark Plug Holes Included: No Valve Cover Holes Included: No Water Pump Holes Included: Yes Thermostat Holes Included: No Timing Chain Holes Included: No Fuel Pump Holes Included: No Distributor Holes Included: Yes Motor Mount Holes Included: Yes Starter Holes Included: No Transmission Bell Housing Holes Included: Yes Accessory Bolt Holes Included: No |
