Zack_008
Zack Zimmerman
Portland Or
(21 posts)
06/29/2019 03:12PM
1931 Ford Buick 215=>281
Buick oldsmobile 215 heads, rocker shafts, 4bl intakes
Posted by: Zack_008
Date: June 30, 2019 01:18PM
Bunch of heads to be considered cores. Total of 9 Buick heads with one needing a lot of work due to corrosion around the intake water jacket. Total of 2 oldsmobile. I do have a second set on a motor yet to be disassembled if there's a curious party. If the chamber size can be determined by the casting, I can get that.
$20+ride for the corroded one
$60/ea or $100 set +ride for the buck heads
$80/ea or $100 set +ride for olds
Total of 9 rocker shaft assemblies. 5 have "Buick " stamped into at least one rocker. Two have no brand visible. One has a broken rocker tip. One has the wrong rocker in the set of intake/ehaust.
$40/ea or $60 +ride per set
One set of Buick heads and 4 bbl that are ported to match. Due to the 6 image limit im just including the intake port comparison to the stock 215. Said intake has been cleaned since pic. Heads are glass blasted.
$300 +ride
One 4bl intake that had been opened up into a single plane.
$100 +ride
All located in Portland Oregon 97233.
Zack five0three . Three2zero . 2 five 98
Also have a couple timing covers, cranks, 300 cranks that need work, core distributors, valve covers, bare blocks, 1 complete Buick, 2 olds,
Zack_008
Zack Zimmerman
Portland Or
(21 posts)
06/29/2019 03:12PM
Re: Buick oldsmobile 215 heads, rocker shafts, 4bl intakes
Posted by: Zack_008
Date: July 21, 2019 10:28PM
Prices are negotiable. Will be at the Good Guys in Puyallup next weekend if there's anyone in the Seattle area that's interested.
