Crank Forging - Raw/Blank Forging - BOP 215/ Leyland McCormack F5000
Afternoon all,
First post here but have quietly been reading the forum for a while here. I'm in the process of building two race engines, one based on an Olds 215 Block, the other based on a rarer Leyland/Repco McCormack F5000 block. I largely hope to only build these once and build them well, with particular consideration taken to the limited number of F5000 units that are around these days, if any. Starting with the rotating assembly, I'm looking for a raw forging or a blank forging to machine down to the Leyland Big end and Main specs (Leyland Mains being larger than Rover/BOP215.) I know the Ford 302 blanks are suitable, I've also heard a Chev crank blank can also be machined down, though I'm chasing the specs on that as the once I've viewed so far take the thrust bearing on the 5th journal. I ask... Where does one source a blank from now? I'm Melbourne based and the foundries that produced these have now gone so I look overseas to see what's available. Thoughts and constructive input welcome... Regards Fraser |
Targa-force-76 John Butler NSW Australia (3 posts) Registered: 06/18/2015 03:23AM Main British Car: 74 leyland p76 rover 4.4ltr |
Re: Crank Forging - Raw/Blank Forging - BOP 215/ Leyland McCormack F5000
Hi Fraser. Located in Oz too. I recently saw ebay UK listings for forged cranks, raw. couldn't they be machined to spec?. They where for a rover v8 design. Hi output engines like the TVR, chimera etc. if I ever come across it, i'll try and put a link in. John
Hi John,
Thanks for that. It would certainly be appreciated as I've not had much luck with securing anything. Regards, Fraser |
