Holley 1848-1 (465 CFM) on intake
This was fitted to my SD1 when I purchased it. The engine ran well apparently; right up to the point a spring broke, a valve dropped and the engine expired. This carb has not run an engine since. The linkages don't appear to be seized, but I don't know much of anything about these; I'm all about the EFI.
This setup alone is 25lb right now, so by the time its safely protected in a sturdy box will be at or over 30lb. This is likely to be around $50 shipping to the east side of the country and maybe $75 to the west - I can get better pricing if you ping me your zip code. Or you can pick up from Louisville KY. Looking at $250 and $25 of that will go to the server funds - see here: [forum.britishv8.org] Happy to do the custard test if you want extra confidence this is genuine. |
Re: Holley 1848-1 (465 CFM) on intake
Suggestion: Use [www.pirateship.com]
