Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
1960 Bugeye, 1974 MGB,Triumph TR8 1.2 115 Hp 1275 in the Bugeye, Nissan Ka24DE in MG
7 Rover V8 engines in California
Posted by: Bugeyev8
Date: August 25, 2024 09:41AM
I've been out of the British car thing a few decades...but came across these v8s after a friend passed away...total of 7 v8 engines...there are 3.5 , 3.9 and 4.0 some are pretty clean and look like poss runners...all have offenhauser 360 4bbl intakes...2 have tr8 oil pans all of them have earlier SD1 front covers...4 have manual transmission clutches and flywheels
I'd really prefer to sell all at once...if not sold after a few weeks ...I'll pull the intakes and parts and sell separately
please if interested message me w a phone number and I'll be happy to call you
Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
Re: 7 Rover V8 engines in California
Posted by: Bugeyev8
Date: August 27, 2024 10:09AM
(4637 posts)
Date: August 27, 2024 10:27PM
Interesting... are those LPG converted engines?
Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
Posted by: Bugeyev8
Date: August 29, 2024 12:09AM
yes they are from Isis motors converted Morgan plus 8s
(4637 posts)
Date: August 29, 2024 02:29AM
Cool. That explains everything. I wonder how many Plus-8-Plus conversions ended up happening...
Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
Posted by: Bugeyev8
Date: August 29, 2024 08:22AM
more than 14...cause i have scrapped a pile of the take off hot wire systems and still have 6...never run
(4637 posts)
Date: August 29, 2024 10:47AM
The last chapters of the Isis story are way under-reported. This article would've benefitted from bigger/better/more photos: [www.gomog.com]
(6590 posts)
Date: August 29, 2024 11:33AM
Saw one of those at the BritishV8 meet in Arkansas. Very tidy.
Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
Posted by: Bugeyev8
Date: August 29, 2024 11:38AM
Bill Fink passed away in a terrible fire a few years back and Steve Miller is prob long dead too...or in prision....they were the only ones i knew that would know those details of production...ect
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: August 29, 2024 03:25PM
Brian, if you end parting them out, I'm interested in one of the intakes and perhaps two of the front covers. Are there any exhaust headers? I've got a Rover 4.2L that I'll be doing some dyno testing on and I don't have an Offenhauser 360 intake.
Thanks,
Dan Jones
Bugeyev8
Brian Marshall
San Leandro CA
(43 posts)
12/16/2008 08:53PM
Posted by: Bugeyev8
Date: August 29, 2024 04:00PM
i have 2 more parted out motors w front covers...and I'd sell an intake....I'm keeping one for my tr8...i have one intake posted on Craigslist
(4629 posts)
Date: August 29, 2024 04:20PM
Yes, we did. It was one of those Isis Imports Morgans with an LS2 under the bonnet. Very nice!
(4629 posts)
What pistons are you using, Dan?
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Date: August 30, 2024 02:47PM
Brian, I sent a PM on the front covers.
That one has a stock short block so OEM standard bore Rover 4.2L pistons and rings. It was some sort of new-old-stock long block that I purchased locally. Someone had backed off the main cap bolts. When torqued to spec, the crank was way too tight so I had my machinist align hone it. Original plan was that it would be a back up engine that would serve temporary duty while I built another engine. It ended up with ported Rover 3.9L heads that flow 190 CFM intake and 136 CFM at 0.500" lift through 1.782" diameter intake and 1.450" diameter exhaust valves. Camshaft is a custom solid flat tappet (228/234 degrees @ 0.050" lift, 0.517"/0.531" gross lift less hot valve lash of 0.018"/0.019", 110 degrees LSA. Lifters each have a 0.024" oiling hole in lifter face. Also has roller rockers and a Cloyes double roller timing set. The heads have been re-shaped with a quench pad and have 23cc chambers. With the thinner head gaskets, compression should be near 10.8:1. Has a TR8 oil pan and front cover with and externally adjustable oil pressure regulator and Ruggles-type booster plate. Baseline intake manifold is a ported Edelbrock Performer but I've also got Harcourt and Willpower single planes to test. Dyno carburetor is a modified Holley 4180
My other 4.2L is a cross-bolted block with Carrillo rods and Wiseco custom forged pistons for a 3.706" bore and have 1.25" compression height.
Dan
