Re: Wanted 215 Olds Automatic flywheels
Art, I may have one.
Did not know that about the Olds. My Buick 215 flexplate that I no longer have was definitely not cast.
joe_padavano Joseph Padavano Northern Virginia (160 posts) Registered: 02/15/2010 03:49PM Main British Car: 1962 F-85 Deluxe wagon 215 Olds |
The flywheel needs to match the trans, not the engine. The Buick two speed AT used a torque converter and a conventional flexplate. The Olds Rotohydramatic 5 used an internal fluid coupling. Without the rotational mass of a torque converter on the back of the crank, the Olds 215 needed a heavy flywheel, even with an AT. The AT flywheel has a spring-loaded damper plate that looks like the center of a clutch disc. The trans has what looks like an MT input shaft that fits into it. The bellhousing on the RH5 trans case is smaller as a result. If you put an RH5 behind a Buick motor, you need the Olds flywheel, and vice-versa for putting a Buick trans on the Olds motor.
OK. I used to have 2 of those. Used them for feet on the leveling jacks on our old RV. Long gone.
