Fel-pro Gasket Set for 215
I have a complete gasket set for a 215 (should fit 3.5). It has been opened but everything is still in the box. Kit part number is FS 7984 SH and includes the following gaskets
O-ring, Dist Mtg. Fuel Pump Mounting Head Gasket Oil Pan Drain Plug Oil Pan Rocker Arm Cover Water Outlet Water Pump Cover Oil Pump Cover Oil Pump Suc. Flange Timing Cover Timing Cover Seal C/Shaft Cap Seals Intake Manifold Seal C/Shaft Rear Brg Seal Exhaust Manifold First $50 gets it shipped |
