Other Cars (British & British-Inspired)
a place to discuss all our other favorite cars, especially the modified and/or V8 ones
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Rover P6 + 4.8 Rover bi-turbo
Posted by: 88v8
Date: August 28, 2020 12:54PM
At a mere £25,500 - yes it's in the UK - here's a very presentable P6 with its original leather interior, and a 4.8 Rover bi-turbo.
Looks almost stock.
A one-off, as the seller says, no one is likely to build such a thing again.
[www.ebay.co.uk]
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Re: Rover P6 + 4.8 Rover bi-turbo
Posted by: 88v8
Date: August 29, 2020 04:32AM
Just to record the basic engine spec before it vanishes:
Cross bolted 4.6 block with an off ground crank 5L BMW pistons and rods
Typhoon camshaft, true roller chain and sprocket set.
Chevy high rev lifters, up rated adjustable pushrods
Cometic multi layer steel decompression head gaskets, 38cc combustion chambers, re-seated large valves, halo spark plugs
New valve springs, steel rocker gear, ported intake and exhaust and port matched intake manifold.
Demon blow through carburettor
Aeroquip stainless steel braided ptfe fuel lines, large Holley fuel pump and fuel pressure regulator.
Digital MS6 ignition with rev limiter, Mallory solid state vacuumless distributor.
Blowing at 8psi.
Ivor
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: September 26, 2020 06:07AM
Now bidding from £10,000 or BiN £18,000. No reserve.
Not a great time to be selling things.
[www.ebay.co.uk]
Ivor
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: October 06, 2020 03:51AM
No bids at £10,000.
Starting now at £4,950 + reserve
[www.ebay.co.uk]
Ivor
Date: January 13, 2021 07:34PM
Sounds like, did not sell ? I wonder about trans and a limited slip ? Art.
(4512 posts)
Date: February 01, 2021 10:41AM
Bi-turbo, Ivor?
88v8
Ivor Duarte
Gloucestershire UK
(1041 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: February 02, 2021 04:07AM
Mmm, did it say so or was I assuming... it's all vanished.
Hard to imagine a V8 with one turbo.
Now you're going to show us examples....
Ivor
Re: Rover P6 + 4.8 Rover bi-turbo or one ?
Date: February 02, 2021 04:45PM
Well, yes there was an example from GM. Predated the Corvair Spyder by 6 mo. +/-. That would be the Olds JetFire !
First , production car application, for Air Research. Small turbine, single turbo with water cooled housing. Waste gated with water/alcohol injection. 10.25/1 compression. Optional BW 4 spd. stick was 2 SECONDS faster in quarter than std. automactic.
Cheers, Art.
