Other Cars (British & British-Inspired)
a place to discuss all our other favorite cars, especially the modified and/or V8 ones
harv8
Martyn Harvey
Waterloo, Ontario, Canada
(189 posts)
10/23/2007 10:09PM
MGB Rover V8, TVR Chevy V8, MGB GT Ford V8
TVR 2500M Steering Rack
Posted by: harv8
Date: July 20, 2010 12:57PM
I have a lot of play in my steering. I understand that the rack is from Triumph 2000 sedan. I also understand that the steering pinion gear is often worn and needs to be relaced. I'm going to check this out in the next week or two. Are there other rack adjustments possible?Any tips?
Also can I use the aluminum rack brackets in place of the rubber mounts that fasten the rack to the chassis? If so, are they the usual ones that are sold or all the TR3,4,6, Triumph steering racks?
Thanks for any help,
Martyn
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Re: TVR 2500M Steering Rack
Posted by: harv8
Date: July 22, 2010 12:42PM
Problem solved!
slow_M
Bernard Holzberg
(59 posts)
07/18/2008 11:12AM
1975 TVR M series Ford 331
Posted by: slow_M
Date: August 01, 2010 01:31PM
Two day fix. Not bad. :-)
Sorry I didn't reply earlier, haven't been active here for a while.
Did you use shims/spacers?
What method was your fix?
I'd always recommend TVR North America for things like this because you're so close.
B.
mgmike69
Mike Gygi
(2 posts)
06/11/2012 12:04PM
Posted by: mgmike69
Date: July 30, 2021 11:52AM
Just curious can you explain how you solved the problem
Thanks
Mike
