harv8 Martyn Harvey Waterloo, Ontario, Canada (183 posts) Registered: 10/23/2007 10:09PM Main British Car: MGB Rover V8, TVR Chevy V8, MGB GT Ford V8 |
TVR 2500M Steering Rack
I have a lot of play in my steering. I understand that the rack is from Triumph 2000 sedan. I also understand that the steering pinion gear is often worn and needs to be relaced. I'm going to check this out in the next week or two. Are there other rack adjustments possible?Any tips?
Also can I use the aluminum rack brackets in place of the rubber mounts that fasten the rack to the chassis? If so, are they the usual ones that are sold or all the TR3,4,6, Triumph steering racks? Thanks for any help, Martyn |
slow_M Bernard Holzberg (59 posts) Registered: 07/18/2008 11:12AM Main British Car: 1975 TVR M series Ford 331 |
Re: TVR 2500M Steering Rack
Two day fix. Not bad. :-)
Sorry I didn't reply earlier, haven't been active here for a while. Did you use shims/spacers? What method was your fix? I'd always recommend TVR North America for things like this because you're so close. B. |
