Other Cars (British & British-Inspired)
a place to discuss all our other favorite cars, especially the modified and/or V8 ones
slow_M
Bernard Holzberg
(59 posts)
07/18/2008 11:12AM
1975 TVR M series Ford 331
TVR M series hub and Brake mods
Posted by: slow_M
Date: October 04, 2008 02:19PM
Here's the modification I'm carrying out to the rear hub/brake on my 1975 TVR M series.
The change is from drum to disk and from a U-joint to CV while increasing the load capacity of the stub axle.
Re: TVR M series hub and Brake mods
Date: October 04, 2008 11:10PM
Interesting. Do you have any pics of what you did to switch from u-joints to CV's?
slow_M
Bernard Holzberg
(59 posts)
07/18/2008 11:12AM
Posted by: slow_M
Date: October 06, 2008 11:18AM
Rob,
The only piece left that is "as supplied" from TVR in these pictures is the cast upright. All the other parts in the pictures are from Nissan 240 except for the two aluminium adapter plates which are custom. I'm using a Toyota Supra Diff and will have custom axles made.
B.H.
Date: October 06, 2008 01:11PM
Got it, that makes sense. I'd like to see pics of the IRS out of the car if you have any. The IRS for my MGB also uses a Nissan 240 diff (actually a Skyline diff, but the housing is the same as the 240 used -- R200S). The unit I have was made by Todd Budde. Uses a custom carrier, upright & control arms & S10 hubs (picked to match my wheel lug pattern).
slow_M
Bernard Holzberg
(59 posts)
07/18/2008 11:12AM
Posted by: slow_M
Date: October 06, 2008 02:00PM
jarred
Jarred Swalwell
(17 posts)
01/13/2010 04:25PM
Posted by: jarred
Date: February 05, 2010 07:13PM
Is the setup the same as the TR6 swap using Nissan 240sx calipers? What did you end up using for rotors?
slow_M
Bernard Holzberg
(59 posts)
07/18/2008 11:12AM
Posted by: slow_M
Date: April 19, 2010 10:05AM
1) no idea (it's homegrown to my design)
2) 240SX calipers & rotors & hub & CVs
B
