1fast02 Thomas Stout Go Vols (2 posts) Registered: 01/20/2017 07:07PM Main British Car: 1968 XKE none as of now |
V8 jaguar XKE
Hello all. I am new to this forum. I have a 1968 XKE FHC. It is in fair shape, no motor or trans, I want to put a supercharged coyote Ford crate motor in it with a six speed trans and a new suspension under it. If anyone has undertaken such a project please let me know or if anyone has any suggestions please feel free to let me know. I'm sure it will be a long process.. so all help is appreciated. Thanks
Re: V8 jaguar XKE
Welcome to the forum Thomas.
Your project sounds like a very interesting project. I suggest you look at the following project thread: [forum.britishv8.org] This is a Gm LS engine going into a 65 FHC so it is not exactly what you are looking for but I am sure it will help. There are four installments and there is lots more work to be done. Not much has happened for a while as Ken must have other stuff on his plate. Send Ken a pm and he will be glad to help you with some of the things to look at. Also please post photos so we can see what you are doing so we can give you advice along the way. Looking forward to seeing progress on your project. Cheers Byron |
Mickey Richaud Mickey Richaud Townsend TN (118 posts) Registered: 08/25/2015 06:36AM Main British Car: '69 BGT GM 3.4 |
Re: V8 jaguar XKE
Welcome, Thomas -
I see from the "Go Vols" tag here, and the area code in your other post that you're in Tennessee. Come on up to Townsend this fall for our informal gathering and you'll be able to meet up with some of us and check out lots of examples in one place. Here's a thread from last year's meet: [forum.britishv8.org]. Don't know how the Talley Ho's reservations are for that weekend, but they usually fill up pretty early. Best, Mickey |
TR6-6SPD Ken Hiebert Toronto Ontario (236 posts) Registered: 04/23/2008 11:43AM Main British Car: 1972 TR6 1994 5.7 L GM LT1 |
Re: V8 jaguar XKE
Hi Thomas,
The link is there that Bryon provided and yes, as you said, "it's a long process". And Bryon is correct, not much has been done on that project recently since I have a few other things on my plate that need wrapping up first. Patience. Ken |
Dan B Dan Blackwood South Charleston, WV (924 posts) Registered: 11/06/2007 01:55PM Main British Car: 1966 TR4A, 1980 TR7 Multiport EFI MegaSquirt on the TR4A. Lexus V8 pl |
Re: V8 jaguar XKE
Why wait until Fall? Lewisburg is not that far from Tennessee....[www.britishv8.org]
Re: V8 jaguar XKE
Hi, Smitty here, as I am new I will keep it short. I owned and built a 1966 xke convertible with a 327 small block chevy in 1969. I live near Chicago Il. I have always wondered why more guys do not do as I did, which is to drop the two square subframe tubes rather than jam a ford 302 in as far as they can until the spark plug wires are jammed against the stock position. It is easy to cut and drop these and if any one ever wanted to go back to stock - save the two pieces and gas weld them back later, or replace with stock pieces This allows you to get any small block down and back. Thus getting a straight line back to the Very strong jag IRS. I even used the stock 4.2 trans with an adapter plate to the gm bell housing. Read up on how much over building went into the original drive train. This setup was going to be ready to take over 750 hp and 500 lb-ft of torque. Jag departed racing due to the bad press of the fatal crash at Lemans in 55 thus never getting the high hp v-12 that was in the works for jags future. I had 465 hp at the rear wheels and drove the car like a madman for 25 years until I sold it - which I still regret! So many of the conversions would look and act so much better if the new engines were down and back. Enough for now. Lots more for anyone ready for a better way. The welded upper subframe NEVER failed and top speed never was achieved as at 142 mph the steering virtually went away due to air trapped under bonnet lifting the car horribly. I know now what I would do to kill that problem but I will end this madness for now. Cheers, Smitty
I I |
