88v8 Ivor Duarte Gloucestershire UK (819 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Rover P6 + 4.8 Rover bi-turbo
At a mere £25,500 - yes it's in the UK - here's a very presentable P6 with its original leather interior, and a 4.8 Rover bi-turbo.
Looks almost stock. A one-off, as the seller says, no one is likely to build such a thing again. [www.ebay.co.uk] |
Re: Rover P6 + 4.8 Rover bi-turbo
Just to record the basic engine spec before it vanishes:
Cross bolted 4.6 block with an off ground crank 5L BMW pistons and rods Typhoon camshaft, true roller chain and sprocket set. Chevy high rev lifters, up rated adjustable pushrods Cometic multi layer steel decompression head gaskets, 38cc combustion chambers, re-seated large valves, halo spark plugs New valve springs, steel rocker gear, ported intake and exhaust and port matched intake manifold. Demon blow through carburettor Aeroquip stainless steel braided ptfe fuel lines, large Holley fuel pump and fuel pressure regulator. Digital MS6 ignition with rev limiter, Mallory solid state vacuumless distributor. Blowing at 8psi. Ivor |
Now bidding from £10,000 or BiN £18,000. No reserve.
Not a great time to be selling things. [www.ebay.co.uk] Ivor |
roverman Art Gertz Winchester, CA. (3075 posts) Registered: 04/24/2009 11:02AM Main British Car: 74' Jensen Healy, 79 Huff. GT 1, 74 MGB Lotus 907,2L |
Sounds like, did not sell ? I wonder about trans and a limited slip ? Art.
