roverman Art Gertz Winchester, CA. (3169 posts) Registered: 04/24/2009 11:02AM Main British Car: 74' Jensen Healy, 79 Huff. GT 1, 74 MGB Lotus 907,2L |
Not Quite a Morgan 3 Wheeler
First off, best of Seasons Greetings to all my friends of BV8.
Back burner project, just got moved up, in priority. As many of you may know, I really dig aluminum. I always wanted an all- aluminum car. Not too many car bodies in my price range,(aluminum). Thinking outside the harbor, I fetched a 12' aluminum boat. Just big enough. What makes it float on water, would tend to do same in air, so "invert". Extend the, new bottom 6-8", to get enough cross-section, ( flat bottom). VW, aluminum, twin tube/trailing link, front suspension. Alum., spindle mount wheels, ( 2 in front). One wheel pusher, in back. Engine/6 spd. trans is Suzuki Bandit, 2016 1250S, with alum swing arm. Alum. wheel is 6" x 17", should be wide enough. Projected dry weight is under 800 lbs. It's a 3 seater, with pilot centered/front. In CA., this will be registered as a home built motorcycle. Onward, Art. |
88v8 Ivor Duarte Gloucestershire UK (979 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Re: Not Quite a Morgan 3 Wheeler
Great.
Something different. There was a rather natty boatmobile sold on BaT a few months ago. Impressive that you can register it in over-zealous CA. Ivor |
Thanks Ivor,
Haven't seen a driving/capsized boat, on the road before. "Boat tailed Speedsters", not quite the same. I see this as a minimalist, vehicle/ boat thinghy. Onward, Art. |
Jim Stabe Jim Stabe San Diego, Ca (811 posts) Registered: 02/28/2009 10:01AM Main British Car: 1966 MGB Roadster 350 LT1 Chevy |
Art - when are you going to post some pictures of all the crazy stuff you talk about here? You know the old saying "If you can't see it, it doesn't exist".
Yes, thank you for the friendly trolling. I visited you. Your turn ?
2021 and beyond..... |
