Robert J Robert Janca Oakland, CA (53 posts) Registered: 10/21/2011 06:31PM Main British Car: 1975 MGB Ford 331 Stroker |
Robert Janca's 1975 MGB 302 V8 Project
Owner: Robert Janca
City: Oakland, CA Car Model: 1975 MGB Engine: Ford 331 stroker engine 9-1 compression. Pistons are made bye JE. Rods are Eagle h-beam. 4340 steel crank the rotating assembly is all 0 balanced. The whole engine was zero balanced together. The cam is a roller xfi cam 575 lift cam was also degreed. The heads are (afr)air flow research 205 outlaw heads and the roller rockers are comp cam magnums. The engine also has a girdle on it with arp bolts. Cooling: TBD Exhaust: TBD Transmission: Freshly rebuilt WC T-5 Rear Axle: Stock to start with. Going with a Ford 8.8. Front Suspension - Pete Mantell's crossmember kit. Completely new suspension and brakes. Fully adjustable upgraded Armstrong shock absorbers, polyurethene bushings and the 3/4" anti-swaybar. I Rear Susp.: TBD Brakes: Stock right now. Future; TBD (master) (front) (rear) Wheels/Tires: 16" Enkei honeycomb mags. Body Mods: Rubber bumpers removed. Flexible air dam (not pictured) and fiberglass tail installed with chrome grille. Interior: Miata leather seats. 3" diameter Roll bar. Electrical: Painless wiring kit Edited 5 time(s). Last edit at 01/26/2013 11:27PM by Robert J. |
