Project Journals
kerbau53
Geoff Morton
Naples, FL
(109 posts)
08/09/2010 10:27PM
78 MGB Ford 5L
Geoff Morton 306 MGB conversion
Posted by: kerbau53
Date: December 08, 2010 10:54PM
Aug 2010. The basis of the conversion. A 1978 with approx. 115,000 km's. (Canada car.)
Bought this 78 roadster off e-bay in Aug 2010. It was 35 miles from my home. Picked it up and drove it home and haven't seen it since. I work in Asia so I can't really do any of the work. Fortunately an old friend was winding up a 58 Chevy project and he's taken the B on as his next project. My job is to source all the bits and pieces. This will end up with all new suspension and a 306. Drivetrain and suspension sourced from Fast Cars. Drop in conversion (almost) becomes cost effective in this case, at least for me.
Owner: Geoff Morton
Builder: Rob Martin
City: Naples, FL
Car Model: 1978 MGB
Engine: Ford 306 crate motor
Cooling: Macs Radiator, cross flow as designed by Pete Mantell who graciously shared the specs.
Exhaust: Through the fender.
Transmission: T5Z
Rear Axle: 8" Ford, 3.55
Front Susp.: Coil over
Rear Susp.: Coil over with trailing links and Panhard rod
Brakes: Wilwoods
(master) MGB dual circuit, non-servo
(front) Disc
(rear) Disc
Wheels/Tires: 15 X 7 wires, 3.5" backspace (-12mm offset) with 205/55-15 Yokohamas
Body Mods: MGC hood (alloy), alloy Sebring front valance, Preform rear valance, Omni flares.
Interior: Mk1 dash with 4" MGC speedo and MGB tach converted to V8 by Speedy Gauges in the UK.
Mk1 steering column rebushed by G. Masterman. Banjo steering wheel reduced to 14" by Doug .
Lepak. Cobra seats, otherwise stock Mk1.
Electrical: Advance Auto Wire.
Additional plans: Air/Con. (Old Air Products, Hurricane 2100)
Basis of the project
Sill repair going bad. Circa unknown.
Dogleg repair done. Circa unknown. Other side has identical repair.
Orange spots are carpet backing.
Surface rust only.
Other side just as ugly but repairable. Left fender is salvageable.
Right will be replaced due to poor prior collision repair..
After sandblasting.
More after sandblasting.
Minor rust repairs completed
Trying to use the least space for AC evaporator. Will eventually convert to RHD and this will make the conversion easier.
Hoses might be larger in diameter than they are long. At least to the center vents.
Tight but looks like it's going to be ok.
Boxed the firewall cutout with C-channel and flat bar.
C-channel structure
Steering is mocked up. Using a vibration damper on the upper u-joint. Intermediate shaft (from Sweet Manufacturing Inc.) is 13+ inches. This is a "Frankenshaft"spline wise. From the top they run 48 to 36 to 48 to 24.
Hopefully this will all work after the firewall is trimmed to fit the engine.
Mk 1 dash extension.
Almost ready for a test drive. "NOT"
Same tunnel trimming required as other 302/T5 conversions
Plastic V8 makes things easier. A/C firewall cover fabricated.
Radiator sitting as high as it will go. MGC hood helps a bit. Actual hood will be aluminum.
Radiator moved forward 1.5 inches with another 1.5 inches cutout forward of the radiator for the A/C condenser.
10.5 inches from block to radiator. Lose 7.5 inches for ancillaries and pulleys. Fan needs to be pretty thin.
Wheels and tires ready to go.
Firewall mods are well documented by others. This is our take on what we need.
A bit too close to the control arm bushing for my liking. Once the drive train is in there may be a bit more space.
A little reinforcing and extra welding.
Widened valance by 1/2 inch. Single strip LED below license plate holder for backup light.
Another LED in the top of frenched portion of valance for license plate light.
Sitting back on her landing gear after 4 months.Cockpit has been Lizard Skinned inside and out. Coil over rear end has been mounted. Flares next.
These mounts were fabricated for us. For reasons unknown to me they increased the ride height apprx. an inch and a half. Built new mounts to drop the rear end to the required height. We now have some adjustment for ride height available on the shock. This will decrease the effective spring rate a bit but I don't think it'll be noticeable.
Following this thread from another forum answers the ride height quuestions.
[www.mgexperience.net]
New mounts. Moved inboard apprx. 2" and slightly to the rear.
Rear end is 53" wide. Most other flared conversions seem to be using 8" rear wheels. I want the same size wheels ( 7") on all 4 corners. I overlooked the fact that this would require spacers or adapters to widen the track for the flares. We can go up to 5/8" wide spacer without replacing the studs. Picture is with 5/8" spacers. Decision has been made to use 1&1/8 inch adapters 5x4.5 to 5x4.5. That will make the track almost identical but a tad wider in the rear. Not desirable by modern car standards but it's relatively faithful to the stock design just 5+ inches wider. Time will tell how it feels on the road.
An original wheel that's suffered over time. It's being fitted with a 14 inch rim borrowed from an Opel GT. Leather wrap to go.
Back to work. Flares being fitted.
Just visible is the hub adapter I had made to correct my measuring error.
First fitting no issues. dropped right in.
Radiator and condenser mounted. With fan installed there's about 3/16ths clearance to the pulley.
Exhaust and parking brake roughed in.
Rear valance and rear flares almost finished. Valance attached with adhesive and the joint fiberglassed over.
OEM 1973/74 grille. Hood doesn't fit so well. No surprise so eased the top of the grille down about a 1/4 inch. Will trim the grille to make it look right.
Grille
Colour and bodywork
Epoxy primer
Base coat single stage
Base coat single stage sanded out on exterior
Exterior with two stage base/clear coat
A/C evaporator being mounted. Inlet - outlet lines will run in the engine compartment rather than the cockpit. If I convert to RHD there will be a bit more fabrication work. Defrost vents will take a bit of work but all in all my goal is to keep all A/C related bits behind the center console except the controls which will go inside the glovebox. Will use dummy heat/defrost controls on the dash rather than welding the holes and destroying the original dash.
With a bit of luck the drivtrain's in to stay.
Clutch pedal bent to gain about 5/8's of an inch. Need to accomodate my size 13's.
Fuse/relay box mounted on a hinge to swing up and latch under the glovebox.
Ron Francis fan controller. The compressor bump up function will be used for manual overide of the fan. The original overdrive switch will be used in lieu of a dedicated fan switch
Ignition box mounted on pax side bulkhead..
Found the hose didn't fit well on the fitting closest to the A/C condensor. Removed the fitting and will tap the water pump and use a 90 degree AN fitting.
Wrapped the steering wheel with a "Wheelskins" leather wrap. Not planning on doing that again. Very time consuming. Looks OK and feels good.
I'm not an audiophile but some rock and roll does my heart good. Where to put a radio and A/C controls? Glove box is the only place left with space so in they go. In keeping with the retro theme the speaker (only one) will go in the original location.
Getting closer. It runs and A/C works. Two silver buttons on the hood are Quick-latch hood pins.
On the ground with a fairly long punch list to attend to.
Exhaust and top are done. Exhaust to be ceramic coated. New rubber on the top except for rear which turned out to be ok. New side plexiglass. Stowaway top to go and interior. All I have to do now is retire so that I'll have time to enjoy it.
Interior is almost complete. The car is on the road.
Finished product. Great fun!
Edited 186 time(s). Last edit at 12/18/2013 06:24PM by kerbau53.
Re: Geoff Morton 306 MGB conversion
Date: April 02, 2014 02:24PM
a
