1995 Land Rover Discovery Special
Owner:Sean Ross
City: Barnesville, Georgia Car Model: 1995 Land Rover Discovery Engine: 4.2L Rover V8 Engine: 4.2L rover v8 with crower 50227 camshaft, hollow pushrods, port matched heads, 3 angle valve job, port matched lower intake and throttle preheater deleted. Cooling: Stock Rover 3 core radiator with viscous fan (soon to be replaced with 3 row welded aluminum unit with dual electric fans) Exhaust: 1985 Rover v8 y pipe with no catalytic convertors, Flow master 54 series 3" inlet/outlet muffler, FlowMaster rear resonator. Transmission: Zf HP22 4 speed autobox with LT 230 1.22 ratio transfercase. Rear Axle: factory Land Rover with U joints instead of rag joint. Front Susp.: factory Land Rover Discovery with Gabriel HD Shocks Rear Susp.: factory Land Rover Discovery with Gabriel HD Shocks. Brakes: 4 wheel disc brakes. (master) (front) cross drilled rotors (rear) cross drilled rotors Wheels/Tires: Factory Discovery wheels with Dextero all season/ all weather tires. Body Mods: TJM rear bumper and Saudi Spec Grille. Interior: Factory with 3rd row seats removed and cargo area sound matt as well. Electrical: rewound alternator 160 amp and lithium ion battery. Edited 2 time(s). Last edit at 05/27/2014 07:10PM by rocketsci2001. |
