scott_mack Scott Mackenzie Cambridge, UK (1 posts) Registered: 04/13/2010 07:56AM Main British Car: 1979 MG BGT Rover 3.5 V8 |
Scott Mackenzie's MG BGT Sebring - 3.5L Rover V8
Owner: Scott Mackenzie
City: Cambridge, UK Car Model: 1979 MG BGT Sebring V8 Conversion Engine: 3.5L Rover V8 The car was originally converted approx 10 years ago but due to daily use it needed doing again so this is the progress so far: Now that all the metalwork has been repaired, the sandblasting has been done and now the filling has started: And this is the bonnet scoop I have had added to try and get some of the heat out of the engine while running: I'll post further pics as the project moves on! Another week on and now there is primer and guide coat after all the filling and sanding has been finished, the engine bay seam sealing has been completed also: Quite a lot has happened since my last update...I'll let the pictures explain for now.... And after a bit more work re-ritting: I've now started on rebuilding the engine, hopefully injecting a little more power as I go....more updates to follow. Edited 2 time(s). Last edit at 03/18/2011 06:53PM by scott_mack. |
