Project Journals
gtownchoppers
Richard Dearinger
Greenfield, Indiana
(11 posts)
02/19/2009 03:51PM
1977 Triumph Spitfire 1996 Ford 2.3 liter
2.3 liter Ford/Spitfire
Posted by: gtownchoppers
Date: May 07, 2009 09:59PM
Owner: Richard Dearinger
City:Greenfield, In.
Car Model: 1977 Triumph Spitfire 1500
Engine: 1996 Ford 2.3 liter
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirerightfront.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977triumphSpitfireleftside.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirecurve.jpg
I got to start driving this in May of 2009, it runs and handles great but there is still a lot to be done. I have been driving it back and forth to work as a daily driver with only a few problems-belt tensioner from some ford(belt eater), freebee supertrapp with no baffle plates( I leave for work at 5am and live in town), alt. will not charge if you don't hook up the IDIOT light, all oversights on my part. Now the good-it starts great every time! To worm it up in the morning I open the pass. door, lean in, put in neutral, insert key and turn! no more get in pump the gas 2.5 times, pray...repeat. Twice the power!
So, What have I done lately?
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfireecuandfuseblockpassfootwell.jpg
I used the ford ecu, silver box in kick panel area, and the Ford Ranger under hood relay/fuse box, black box. When I get to putting the glovebox in, I'll be able to access the box but not see it from the seat. I'll make kick panels to cover the ecu and finish the footwells.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirefuseblock.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfireenginefromfrontleft.jpg
Changed the fan from a pull to a push. I am planning to make aluminum front air shields that will incorporate the radiator mountings, fan mounts and house the air filter.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirepasstranscover.jpg
I moved the front of the passenger footwell back about six inches to accomadate the side exhaust. The sides of the trans. cover are fixed with a removable top, the top still needs some work. Every weld will be finished when the tub comes off, for now they hold things together and help keep the wind out.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirelefttranscover.jpg
The duct tape is covering the access hole for the clutch line, as long as it keeps the winter wind off my leg, it'll be here soon, I'll put off making the cover.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfiredriveshafthump.jpg
I had to replace the drveshaft tunnel to fit the larger driveshaft joints, so moved the handbrake to the correct side, I'll need to move it forward and down to get it right with the planned center console.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirefloorfromrightabove.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfireleftdoorhandle.jpg
Removed and refinished the door handles, they were looking pretty rough, now, nobody notices them----------but me.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/1977TriumphSpitfirefueltank.jpg
I'm thinking I might make a aluminum tank to replace this one. A little bigger and with all the holes in the top.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/doorcard.jpg
I spent a couple weeks working on new door cards, the ones in the car were awful, a bent and twisted mess covered in 1980's bad sofa fabric. I made a template to cut these and put an ad for them in the classified section.
PICTURES FROM EARLY IN BUILD (OLD PICS)
passenger side-the fan pictured has been replaced with a pusher, the belt tensioner has been removed, tension is provided by shims.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3092.jpg
driver side-Yes it sticks out the hood but a volvo twin-cam head should get it all under the hood.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3093-Copy.jpg
driver side motor mount
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3094-Copy.jpg
steering rack from driver side
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3095.jpg
steering rack from passenger side- just enough room to get the belt through.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3097.jpg
fuel tank with internal fuel pump-I used the stock ford ranger pump(with the ford mount cut off), the original spitfire delivery line is now used for return, I cut the vapor return line fitting off and enlarged the hole so the pipe fitted to the ranger pump would fit through.The wires in the tank run to the two screws in the spitfire tanks sinding unit cover, the sending unit still works.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3105.jpg
motor mounts-I used the engine side of the ford mounts, I cut them to down to the part that bolted flat to the motor, on the pass. side this left me with two pieces I bolted them ontothe block and joined them with 3/16" plate.
After much hunting I found rubber bushings at a john deere dealer in town, I turned the frame side mounts(pipe) I.D. to match the O.D. of the bushing and cut it about 1/4" shorter than the bushing then welded the pipe to a small plate that could be welded to the frame. I made discs(two each side) a 1/4" larger than the pipe with a hole in the center that is the same size as the bushing I.D. I then cut a flat on the discs(the discs now look like a fat "D") I put the bushing in the pipe and bolted a disc to each end of the bushing then welded a pipe, that had been cut to the length of the bushing and then cut in half to the discs. I now have two parts that can be bolted together through a rubber bushing.
I bolted the plates to the block, positioned the engine and trans. where I wanted them and set the bushing assembles on the frame rails. I tried to center the bushing assembles on the bolt patterns of the plates. I turned the bushing assembles slightly away from straight, clockwise on the right counter clockwise on the left, to prevent the engine from moving forward or back, and then tack welded them in place. I then used 1"x2" tubing to connect the plates to the bushing assembles. checked engine position, welded it all up.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3110.jpg
passenger side motor mount
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3111.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3114.jpg
oil filter-this filter is shorter than the stock unit
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3115.jpg
Cooling: Triumph Spitfire radiator/the fan has been changed to a pusher
Exhaust:I modified the stock Ford Ranger header-I cut all 4 runners about 1 1/2" from the head, posisioned the collector where I wanted it then fitted pipe to each runner, welded up the egr port wraped it all in heat wrap. the supertrapp has been replaced with a muffler made from two vw bug mufflers. Its still loud but the neabors lights dont come on when I start it.
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3118.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3100.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3099.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3098.jpg
Transmission:M5od 5 speed
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3112.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3104.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3103.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3102.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3101.jpg
Rear Axle: stock
Front Susp.: stock
Rear Susp.: stock
Brakes: stock
(master)
(front)
(rear)
Wheels/Tires: stock
Body Mods: hole for exhaust
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3117.jpg
http://i291.photobucket.com/albums/ll283/gtownchoppers/Spitfire/102_3119.jpg
Interior: stock
Electrical: Ford eec-v pcm, stock
Edited 8 time(s). Last edit at 09/03/2010 02:37PM by gtownchoppers.
(4636 posts)
Re: 2.3 liter Ford/Spitfire
Date: March 14, 2011 08:55PM
25
