Alpine Rear
Hello All
I road race a 61 Alpine and want to put a better rear With a LSD and would like to keep the same lug pattern and all so not spend a fortune does any one know if a mustang II rear will work without shortening it ? and what the dimensions are ? Thanks Rocco |
Re: Alpine Rear
I have a narrowed mustang II 8 inch in my alpine. Theres some discussion on it here.
[www.sunbeamalpine.org] |
Orange Alpine Bill Blue (45 posts) Registered: 12/20/2010 07:36AM Main British Car: 1967 Sunbeam Alpine 2.5 Ford Duratec |
Re: Alpine Rear
For all practical purposes, the answer is no. Guys have done it, but no one says it is a good thing. Maybe if you run wheels with a lot of offset.
Bill |
gt40mk1 Pat Cargan Biggin Hill, Kent, England (18 posts) Registered: 12/30/2010 03:22PM Main British Car: 1949 Jowett Javelin 318 cu. in. Chrysler |
Re: Alpine Rear
Some early rwd Toyota Celicas had lsd, wont be the same bolt pattern, but may not be far off the correct width.
Cheers, Pat. |
Re: Alpine Rear
GM Monza,Skyhawk,Starfire right bolt pattern and with FWD offset wheels may work,thick spacers in front. May still be slightly wide so skinny tires or flares.EDIT: Spridget bolt pattern not Alpine! The only ones narrow enough that I know of are Postal Jeep(72-75 CJ5 4x4 also)or maybe MGB. Not that hard to change bolt pattern.
Edited 1 time(s). Last edit at 02/07/2011 03:42PM by mgb260. |
Re: Alpine Rear
I met a guy at a car show a few weeks ago that said he had an alpine, and in the 80s the rear end went out in it. He said he went to a junkyard and measured to find something close and i think he said it was a dodge colt (it was a small dodge car)that was the same from drum to drum. He said when he got it home, it actually bolted right in, the spring perches were in the same place. I didnt see the car, this is just what i was told. I doubt that is an LSD but it may be a bolt in option.
