Frizzle Fry Mike Dempsey Oregon (28 posts) Registered: 11/19/2008 11:05AM Main British Car: 1966 Sunbeam Minx Honda S2000 F20C |
S2000 Minx
Hello all,
New member here. I have a 1966 Sunbeam Minx with an ailing 1725. I've been searching for a suitable swap to modern EFI and have come to the conclusion that the S2000 F20C and 6-speed are the perfect match for this car (small, light, and powerful). I've seen the article on Joe Curry's 1963 Spitfire and was hoping to get in touch with him or someone else with experience with these engines. Specifically I'd like to know what ECU reprogramming was done and what software was used to do so. Same question on the wiring harness; what mods were required? Fuel pump used? Also, and this is a big one, I've read that Honda engines spin the opposite direction versus "conventional." Is this the case for the F20C and if so what rear was used? Perhaps a "conventional" rear could be flipped? Obviously there are quite a few details to sort through, but I enjoy this kind of challenge. Any info would be greatly appreciated. Here are a couple pics of the car for your viewing pleasure: |
Re: S2000 Minx
Not familiar with the Minx so let's start w/some basics... like engine length, width, & height -- e.g., will it fit w/o a lot of cutting/welding etc.
Transmission tunnel -- width of the tunnel support the 6 speed you're looking at? Rear end -- will it hold up to the torque of the S2000 (no idea what the torque is but something to consider) Fuel pump... I'm guessing that car's tank doesn't have a return line so you'll need to plan for that... and depending on the fuel requirement of the S2000 motor, you may need a larger fuel supply line. Just some thoughts to get the ball rolling. |
Re: S2000 Minx
Wow. Saucy Minx!
I don't know much about Honda engines - hopefully experts will chime in shortly - but I know a cool looking car when I see one. I bet there's room in that engine compartment for lots of different engines. More photos would be fun to see, if you've got time. |
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (384 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3 |
Re: S2000 Minx
I take it that his engine bay is very similar in size and type to the Alpine? The front looks very similar.
Do you have any dimensions of the S2000 engine? Where does the shifter sit compared to the very front of the engine balancer/pulley? Are you going to run into shifter issues inside the car? -BMC. |
Re: S2000 Minx
rficalora Wrote:
------------------------------------------------------- > Not familiar with the Minx so let's start w/some > basics... like engine length, width, & height -- > e.g., will it fit w/o a lot of cutting/welding > etc. > > Transmission tunnel -- width of the tunnel support > the 6 speed you're looking at? > > Rear end -- will it hold up to the torque of the > S2000 (no idea what the torque is but something to > consider) > > Fuel pump... I'm guessing that car's tank doesn't > have a return line so you'll need to plan for > that... and depending on the fuel requirement of > the S2000 motor, you may need a larger fuel supply > line. > > Just some thoughts to get the ball rolling. It’s not really a matter of will it fit. Take this V8 Husky for example (basically same as a Minx from the doors forward). [www.whatsahillman.com] It’s a matter of how little can I cut. That will be answered as it goes in. Fabrication is not a problem. The engine/tranny are on the way so I’ll find out one way or another… The rear end I figure I'll run the stocker until it either dies or I decide it needs to go. Then I’ll probably go with a Dana from an old mail Jeep or a Tiger rear. I’ll figure out what ratio I need based on how it feels with the stocker. IRS would be cool, but I want to keep it simple. Fuel pump and lines are a good question. One I hope I can get answered by someone who’s done an S2000 swap. Thanks for the response. Moderator Wrote: ------------------------------------------------------- > Wow. Saucy Minx! > > I don't know much about Honda engines - hopefully > experts will chime in shortly - but I know a cool > looking car when I see one. I bet there's room in > that engine compartment for lots of different > engines. More photos would be fun to see, if >you've got time. Thanks. I’ll definitely post more pics as I go. BMC Wrote: ------------------------------------------------------- > I take it that his engine bay is very similar in > size and type to the Alpine? The front looks very > similar. > > Do you have any dimensions of the S2000 engine? > Where does the shifter sit compared to the very > front of the engine balancer/pulley? Are you going > to run into shifter issues inside the car? > > -BMC. I don’t know how similar it is to an alpine. The shifter location I have looked into and though I don’t have the exact dimensions, I do believe with a little fabrication I can move the shifter forward on the tranny if needed. Here’s a pic of an S2000 engine/tranny: |
Re: S2000 Minx
Back for an update. I've made a some progress. All the pics I have uploaded so far can be viewed here: [s6.photobucket.com]
and here's a teaser shot: |
Re: S2000 Minx
This is a really cool project!
Some really well-taken photos too... this one is worth a couple thousand words. ![]() Hey, did you see that since you posted here last we've added a "project journal" section? In my opinion, it has a couple big advantages over Photobucket - especially from a visitor's perspective. No thumbnails, and thus no mouse-clicks. (While the visitor is looking at one large image, other images are loading.) Also, you can intersperse captions and comments easily. |
Re: S2000 Minx
Thanks. I'm still looking for the best place to post a project thread. To be honest I prefer to have the ability for members to leave feedback. Many times there are good questions and/or suggestions.
Re: S2000 Minx
Well, the project has come a long way since I last posted here. Thought I'd drop by any share my progress. Project update here: [speedhunters.com]
Re: S2000 Minx
Looks great Mike. I really like the way you incorporated the S2000 shock towers into the Sunbeam chassis, very nice workmanship.
Bratfink James Bratby Indianapolis (12 posts) Registered: 09/29/2010 04:05PM Main British Car: 66 MkIV Singer Vogue Estate 1725 (with Alpine S5 twin carb) |
Re: S2000 Minx
Hmm,
I have the same plan, only mine is to stuff a 240SX motor (cheaper) into a MkIV Vogue. Front end is the standard 'Super' design though. The most fun seems to occur with that steering linkage and clearance of the exhaust. Hence pick a motor that has the same intake/exhaust orientation as the rootes. I'll be watching this with interest! Couple of questions: Why all the Sunbeam scripts on a Hillman Minx? Was it called a Sunbeam in the US or something? In the UK the Sunbeam version of this body style was the Rapier. Also are you sure about that old engine being a 1725? Looks in the picks more like a 1500 with an iron head. What happened to that old lump? Parts for them are getting hard to find now. Edited 1 time(s). Last edit at 09/29/2010 04:52PM by Bratfink. |
Re: S2000 Minx
Excellent work, looks great!
Rootes stopped using the Hillman name in the US in the early 60s. They were afraid of the bad reputation the Easydrive transmission got in the Hillman Minx. So we have Sunbeam Minxes, Sunbeam Imps, Sunbeam Arrows (Hillman Hunter) and even a Sunbeam Funwagon (a Commer caravan) The engine would be a 1725, but in base spec with just 1 carb and a cast iron head. My Arrow estate had a similar engine, but I've made quite a few mods, including an alloy head, Alpine cam, and a custom EFI system. |
Re: S2000 Minx
hi i am new here and glad to join this forum community .. i am not more familiar with car engines but i know the powerful engines is like S2000 engines .. I like it ..
Re: S2000 Minx
Hey guys. Well we're coming up on three years on this project ...still progressing! Not sure if I ever posted the link the my build thread. Here is is: [67-72chevytrucks.com] Over 41 pages of mayhem there. Not far now!
Re: S2000 Minx
Wow, it's come a long way! Looks like plumbing your intake and painting the engine bay... What else do you have left?
Re: S2000 Minx
Brake lines, fuel lines, wiring, exhaust, bodywork and paint engine bay, trunk, dash, trans tunnel, Raptor-liner wheel wells/underside, powder coat suspension pieces, dynamat interior, and 1001 misc items... But I'm pressing on!
HealeyRick Rick Neville (495 posts) Registered: 12/19/2007 05:01PM Main British Car: 1963 Austin-Healey 3000 Ford 5.0L |
Re: S2000 Minx
Just cheked out your build site, that's some fab fab (fabulous fabrication)! Personally, I'm not digging the wheel choice. With that sedate body and those blingy wheels, it's kind of like outfitting your grandma with a thong from Victoria Secret. Maybe some big steelies would help with the sleeper look and would pay for themselves after you suckered some tuner cars into a few street races. Just my opinion, your mileage may vary.
DC Townsend David Townsend Vermont (407 posts) Registered: 11/21/2007 12:22PM Main British Car: '78 B (almost done) 30-over SBF, dry sump |
Re: S2000 Minx
"...it's kind of like outfitting your grandma with a thong from Victoria Secret. "
Cracked me up! Neville, that has to be the best comment I seen on this site in a long time. Should be an award of some kind for it. Oh yeah, went through all 41 pages of the Minx build. Just don't seem to be enough superlatives to adequately describe the skills, ingenuity, and daring. Fearless! Edited 1 time(s). Last edit at 10/30/2011 10:28AM by DC Townsend. |
Re: S2000 Minx
My grandma looks amazing in a V.S. thong ;) The wheel choice was made in pure hotrodding tradition; use whatcha got! I had them left over from another project and they happened to fit the S2000 lug pattern. The front tires could use a little more side-wall IMO and that contributes to the blingification effect. I dig the wheels on this car though (hated them on the previous ride). Trust me, it takes more than a set of wheels for the ricers to tuck tail. If anything a touch of bling is a provocation.
However, I am planning to do a 2nd set in 16-17" steelies with the factory dog-dish caps. Glad you guys enjoyed the build so far. -Mike |
