Re: Ghost 66 Alpine
John, Wow! Full frame. Have you thought about going narrower on rear and tubs inside instead of the huge flares? Do you plan to flare the front and run a standard width Mustang II front suspension?
Orange Alpine Bill Blue (45 posts) Registered: 12/20/2010 07:36AM Main British Car: 1967 Sunbeam Alpine 2.5 Ford Duratec |
Re: Ghost 66 Alpine
Why not split the car lengthwise and add 6 inches to the width, like John did about ten years ago? It is easy enough to say, implementation might be a bit difficult.
BTW Jim, do you have any idea what happened to that beauty? Bill |
Re: Ghost 66 Alpine
Bill, I remember reading about it. Most radical jobs do not get finished. There is a Alpine on the SAOCA board using a full width rear with positive offset wheels with more subtle VW Rabbit flares.
Edited 2 time(s). Last edit at 12/22/2017 10:04PM by mgb260. |
Re: Ghost 66 Alpine
John, Cool! Checkout the electric power steering that our friend Dan on the SAOCA board offers.
[forum.sunbeamalpine.org] Edited 2 time(s). Last edit at 12/23/2017 05:44AM by mgb260. |
Re: Ghost 66 Alpine
Re: Ghost 66 Alpine
Re: Ghost 66 Alpine
Nice looking front end.. We're talking about something similar for the Ghost...
Mentioning the Ghost.. I'm trying to think of vanity plates... 66GHOST GHOST SUNBEAM NERVOUS TGRKLLR TGRHNTR any ideas? |
Re: Ghost 66 Alpine
The electric power steering is continuously adjustable from Pinky steer all the way up to Armstrong (no assist). Or so I've been told, but I have no reason to doubt. Am in the process of installing one now.
Bill |
Re: Ghost 66 Alpine
Re: Ghost 66 Alpine
Re: Ghost 66 Alpine
Re: Ghost 66 Alpine
Tiger2Dan Dan Richardson Greenwood, SC 29649 (8 posts) Registered: 02/04/2018 12:16PM Main British Car: 1967 Sunbeam Alpine Series V ST Colour Code 106 FORD (Cologne) 2.8 V6 |
Re: Ghost 66 Alpine
My Sunbeam Alpine has a bit of what I'd call an aerodynamic problem at really high speeds:) The fender flares might prove even worst. Hope not:)
Lots of talk about the different engine mod's for an Alpine led me to the Ford (Cologne) 60 degree Engines (2.8 & 4.0 V6's). Absolutely no "torch" work! Only time for any welding are the two bottom engine mounts! Tight, YES! But, It fits rather nicely. I started with the 2.8 V6 Conversion "kit" I purchased back in 2012. Good quality, poor design IMHO, so I started my own! First was the Headers sticking out the side (I did not like having to reroute the exhaust), so Mine are straight back similar to the Tiger system. Then, the engine mounts hanging off the rear of the crossmember was not to my liking either, so a new design with built in stops for setting the engine in position so there was adequate spacing between the radiator and fan ( I even have enough space to run dual pulleys for Air Conditioning)! AND John, Your comment about: Quote: "I'll think about the Electric Steering, We're working towards a Wifeable, Streetable Race car, so not sure whether the Raceable side would work with an electric Steering... Clean system he came up with though! " Unquote Leads me to the fact that the EPS can be worked with the power on or off. Off is normal steering, On is a choice you can select. In other words your wife can make it as easy as she pleases:) Love them Sunbeams - Keep'em on-the-Road. Best of wishes to you and the Ghost, DanR |
Re: Ghost 66 Alpine
John, Your front spoiler may be too low. When your car is on the ground with the motor in, a good rule is nothing should hang lower than the bottom of the rim. Shocks, oil pans, front spoilers, etc. If you have a tire blowout it could create a lot of damage.
Re: Ghost 66 Alpine
Great point, it is, above the loaded Rim and Rocker Panel, but it is low, I’ll have a custom oil pan, all my packeage should be above the low water mark..
I also agree it’s a bit blocky to be really fast, but with the BHP we are putting in it, north of 600 I think I’ll still have a fast little booger. Edited 2 time(s). Last edit at 02/05/2018 07:39AM by nakedhacienda. |
Re: Ghost 66 Alpine
