Rootes Group Cars
TBaker
Thomas Baker
Houston, TX
(8 posts)
02/04/2021 06:52PM
59 Hillman Minx convertible 2.0 Turbo Ecotec
2.0 turbo Hillman Minx project
Posted by: TBaker
Date: March 13, 2021 09:39AM
Hi all,
I recently acquired a 59 Hillman Minx Convertible in fair condition. Only a small amount of rust that I've already repaired and the engine runs like a top. Unfortunately, it runs like a 53 hp/ 90 ft/lb top and that's where you all come in! I also happen to have a 2.0 turbo Ecotec from a 2018 Camaro that is 275 hp and 295 ft/lbs of torque along with the 8 speed transmission. Has anyone here done an Ecotec swap? With the Sunbeams also being Rootes group cars, I'm hoping somebody has some advice regarding front suspension and rear axle. I enjoy the restored cars, it's just that I'm more of a modified performance guy and this Minx has some potential to be unique to say the least! I'm not shy about the cutting and welding, the stand alone wiring harness or making things fit, but I'm no steering expert and the Hillman's front suspension/steering will likely conflict with the engine swap. Thanks in advance for your thoughts.... love reading the success stories on this site!
Tom
TBaker
Thomas Baker
Houston, TX
(8 posts)
02/04/2021 06:52PM
Re: 2.0 turbo Hillman Minx project
Posted by: TBaker
Date: March 17, 2021 11:57AM
My Hillman uses a steering box located on the frame rail (right below the steering column exit through the firewall), that connects to something of a tie rod that parallels the firewall. So it runs behind the engine and above the transmission. My new driveline combo being a modern 2.0 turbo ecotec and transmission will likely conflict with that, so does anyone have experience with alternate steering/crossmember combinations? I've seen a Husky with a narrowed Mustang II with rack and pinion, but that is going to very expensive. I'm hoping someone has gone down this road looking for alternate methods. Does a Sunbeam steer this same way?
Tom
Edited 1 time(s). Last edit at 03/17/2021 12:45PM by TBaker.
(2631 posts)
Date: March 17, 2021 05:01PM
Dan R on the SAOCA forum has a arched tie rod or spacers to lift yours. Alpines have the same setup.
[danr.mhartman.net]
Edited 1 time(s). Last edit at 03/17/2021 05:04PM by mgb260.
TBaker
Thomas Baker
Houston, TX
(8 posts)
02/04/2021 06:52PM
Posted by: TBaker
Date: March 17, 2021 07:16PM
Great tip..... Thanks! The turbo down pipe will have to clear on a full left turn, but this could solve my steering issue
TBaker
Thomas Baker
Houston, TX
(8 posts)
02/04/2021 06:52PM
Posted by: TBaker
Date: March 20, 2021 09:41AM
After the tip from Jim Nichols, I'm feeling much better about the steering system I have in the Minx (since it's the same as the Alpine). I went through the photo section and saw a lot of V8 cars using the stock steering with an arched tie rod or spacers so my modern 4 should be easy to steer. Does anyone have experience with rebuilding the front end? I've found poly bushings on line, but I rebuilt an El Camino once with poly bushings and didn't like the ride. This car is a cruiser, not a racer at all. I've looked for rubber in the usual places with no luck so is there another car that uses the same parts? I'm not sure that my parts are all that bad, but it would be foolish not to renew the soft parts when the engine is out. Thanks in advance.
Tom
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: April 19, 2021 05:16AM
Here, from a seller of few words, is a nearly completed 59 Minx with a 3.9 Rover V8.
Apparently it 'drives' with no radiator. Well I do recall years ago a member of the TR Register briefly starting his newly built motor with no water in it... 'I only ran it for a minute' he responded to the howls of anguish...
[www.ebay.co.uk]
A rare sighting of a rare beast.
Ivor
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
1972 TR6 1994 5.7 L GM LT1
Posted by: TR6-6SPD
Date: May 04, 2021 08:54AM
I followed this build of a '66 Sunbeam Minx, started back in 2009:
[67-72chevytrucks.com]
Somewhat related.
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: May 05, 2021 04:50AM
2009-2018... how life gets in the way... lol... but a very smart ending.
Ivor
