Font Size
Hi Curtis. Good luck with the forums.
One comment - while the headers are normal size, the text of the posts is in a tiny font that is hard to read - is that something you can adjust? Bill |
Re: Font Size
Hi Bill,
I just put down my dial caliper... and I've verified that - on my screen anyway - text in the posts appears exactly the same width as what Skye uses on the "MG Experience" board except that I'm using the "Arial" font. (I think he's using "Verdana" or something... the characters are a little less rounded.) How does text on The MG Experience look to you? Should I display text bigger than Skye does? I need to go up to the library this morning and see if text appears smaller on their monitors than it does here at home. It could be that I have a bug in my program and not everyone is seeing the same text size. In the meantime, in your browser toolbar there should be a text size "zoom" option... and it'll let you enlarge or shrink the text. I hope that helps for now. THANKS FOR GIVING ME CONSTRUCTIVE FEEDBACK! Very helpful! -Curtis |
Re: Font Size
Curtis, the header is a nice size - shows as 13 pitch when copied into Word, but the body is 11 pitch and a bit small for easy reading - yopu may be able to adjust that in the software.
Oddly, when composing a message, it shows in large font. |
kayakjack John Renaud Michigan (35 posts) Registered: 10/23/2007 01:46PM Main British Car: 1980 MGB V8 Buick/Rover 3.5L |
Re: Font Size
Hi, Curtis, What a great web site! I do agree
that the font could be 25 - 35 % larger. It would make easier reading for some of us who are a little long in the tooth. Regards, Jack |
Re: Font Size
If you guys would use Mozzilla Firefox, there are some great zoom plugins, plus I just hold down my ctrl key & use the mouse scroll wheel to adjust text size.
Jacmo Jack Morris Chattanooga, TN (9 posts) Registered: 10/28/2007 08:46AM Main British Car: 80 MGB Chevy 355 ci (Donovan Aluminum) |
Re: Font Size
Text size seems fine to me. In fact, my first impression was that it was a nice, larger than normal size. (I'm 63 and use drugstore reading glasses). The font size in the reply section of a post is smaller than what appears in the already posted message, on my end.
Re: Font Size
Guys, I'm sure that getting new browser software or learning special commands might in some cases do the job, but when all the other boards out there are more user friendly and present the information in an easy to read way that doesn't require any effort on the part of the reader, the fact that this one does not will inevitably be reflectedd in less use, and that's not what a board creator wants.
I think it is incumbent on the owner to make the board settings suit most viewers, not vice versa. |
Edd Weninger Edd Weninger Mogollon Airpark Overgaard AZ (22 posts) Registered: 10/28/2007 12:49PM Main British Car: 1977 MGB Rover 3.5 L EFI |
Re: Font Size
Bill,
The current body text looks large enough on my terminal, in fact larger than the other boards. I can read it easily without my geezer glasses. |
Re: Font Size
Edd Weninger Wrote:
------------------------------------------------------- > Bill, > > The current body text looks large enough on my > terminal, in fact larger than the other boards. > > I can read it easily without my geezer glasses. Not on mine - far smaller than other boards, which use a font the size of the Re:X at the top of each post on this one. This is the same in Explorer or AOL for me. |
Re: Font Size
Well... I bumped the text size up LAST NIGHT, so it should be significantly better than it was before...
I started by installing the same basic software package that's used by "The MG Experience", and I set the font size for the main message section to be the same as Skye had his set for. I set the font to Arial because I think it's easier to read and more attractive than Verdana. I was surprised to hear that messages looked smaller here than on that message board. Just for reference: on my monitor right now the phrase "The current body text looks large enough on my" measures 103mm wide, whereas when I paste the phrase into "The MG Experience" it appears 93mm wide. I have both a Mac and a PC, and I usually test on two different monitors and on several different browsers (Firefox, Safari, Netscape 7, etc.)... but not the latest version of Internet Explorer (because I dislike it, and because it won't run on my PC unless I update my operating system...) Anyway, the software we're using ("Phorum") has a goofy way of defining how text appears from one place to the next. It's going to take me awhile to get that redesigned and streamlined, and once I get it the way I want it it'll be a little harder to migrate to future editions of the Phorum software. I guess that's just the way things go we're you're a hot-rodder! |
Re: Font Size
p.s. copying text into Word to see what size it is doesn't seem to work for me. (Should it?) When I copy text from here into Word it converts to whatever the default is in Word... Times New Roman, size 12.
Re: Font Size
Yeah, copying doesn't seem to retain font size.
In your previous post the words 'LAST NIGHT' show up in the same size as all the posts on the MGB forum do for me. |
Re: Font Size
Okay, I'm now at my mother-in-law's house and I'm using her PC which has Internet Explorer 6.0... now I can see what you've been seeing.
In the toolbar at the top of the screen there's a pull-down menu labeled "View"... and the seventh option down in that menu is "Text Size"... and if you select it, it'll give you the options "Largest", "Larger", "Medium", "Smaller", and "Smallest". At least on THIS computer, if you set the text size to "medium" then the message text will appear quite large. However, when I first sat down at the machine I found that my mother-in-law had previously set text size on "smaller", which is indeed quite small. Now... just for grins I pulled up the MG Experience forum. Skye has all his fonts defined in "pixels" instead of in "ems", so as a result he has defeated the Text Size option/function. It doesn't matter whether I select "Largest", "Smallest", or in-between; messages always appear a constant size that falls in-between the proper/correct/industry-standard/square-with-the-world "Smaller" and "Medium" size (as seen on this forum). --- p.s. (back home now...) as of Monday morning, I've made some tweaks that should improve how the forum behaves for IE users, and I've got a couple more tricks up my sleeve yet. Please let me hear if there are further concerns. -Curtis Edited 1 time(s). Last edit at 10/29/2007 02:52PM by Moderator. |
Re: Font Size
Hey, Carl, I use Firefox and using the ctrl key & the mouse scroll wheel to adjust text size
works great. I'll be using that in a lot websites. Thanks. Regards, Jack |
