Doc Hopalongfoot Marc Weitzman Huntingto Woods, MI (58 posts) Registered: 01/22/2008 11:45PM Main British Car: 1979 MGB roadster ford 302 |
check my progress
Re: check my progress
Marc,
Earlier this month, Jack, Tom and I stopped in at the body shop to see the progress of your conversion. - it's coming along nicely. Let's hope that it gets the required attention for a timely completion for the Wisconsin show. |
I like the way the headers come together where they go through the inner fender. I have a set pre-made for the MG/302, but they requrie a bigger hole. I've been toying with ideas to make it look better but may not get to it before Wisconsin. I've been toying with the idea of painting the under-side & outside of the car but leaving the engine bay & front inner fenders in primer so I can get my car done enough for Wisconson, then change some things like that afterward.
I also like your motor mounts although they look a bit light from the pics. What gauge are they? |
Thanks Graham,
I appreciate the good wishes. Now that the headers are going to the ceramic coaters the motor is coming out to be detailed and we start on the back end. Bobby V told me your input was very helpful. Do you know of anyone that uses different size wheels on the front and back? We are thinking of moving the rear springs inboard to allow for wider wheels in back, but the front may not handle that size. What rear end ratio do you think is best? Bobby is planning to have a custom gas tank fabed and along with the flaming river steering rack we are doing a few different things. I hope you stop by before the next WDMGC meeting in Windsor. Thanks again, Marc |
Marc, for custom fuel tank check with Todd Budde. He makes a really nice aluminum tank for the B. It's set up with an internal fuel pump, baffling, AN fittings, sender, etc. Ready to bolt in for fuel injected applications. He'll also do it w/o the fuel pump if you're going carburated. I just got mine delivered yesterday & don't have any pics, but check out this post where Bill Guzman posted some great pics & info...
[www.mgexperience.net] Good luck, Rob |
Hi Rob,
I like the position of the headers myself. They are way back in the fender well and out of the way of the wheels and tires. The mounts do look a bit on the thin side, I don't know the gauge, but I'll ask Bobby and get back to you. Thanks for the info on the gas tank, the one we were going to use was custom and expensive. I'll check this one out and see if it fits the bill. Good Luck getting ready for the 08 meet, Marc |
Marc,
Using different size rims (and/or tires) for front and back is certainly a subject that many embrace - you could search the "Photo Gallery" articles for those that have done this - Joe Schafer, for instance, runs similar rims but smaller tires on the front. Personally, I prefer the same rim/tire combination to allow tire rotation and have a spare tire w/matching diameter. On the subject of rear axle ratio, I am running a 3.27 which I find matches best with my 23.8" dia tires and a 0.68 OD T-5 transmission ratio. This translates into 1880rpm@60mph, 2193rpm@70mph, & 2507rpm@80mph, for example. I suppose that if you plan to use a taller tire, or would like a bit more acceleration capability, a 3.55 ratio might be appropriate. Assuming your T-5 OD ratio is the same as mine, you might find a 3.07 ratio too slow for highway driving. Like most things, it becomes a matter of personal preference. |
MGB SS Joe Schafer Central Michigan (150 posts) Registered: 10/23/2007 06:46AM Main British Car: 1971 Mgb 1991 5.0 Ford |
Hey Marc
Good to see that you are underway. As to different size wheels and tires I agree with Graham on the ability to rotate tires on a daily driver but on my 4000 mile a year toy I like what makes the car work or look the best. Are you keeping the front 4 bolt pattern? What rear are you going to use in the rear and what pattern on that. I like my 3.42 rear gears but as mentioned above it is preference. Is the shop near your home, I Have been working in Detroit lately, give a shout. Joe |
Hi Joe,
Its good to hear from you. The shop is in Windsor, over the river , and I don't get there as much as I'd like. Its frustrating not having the room, time, talent, or tools to do it myself. 3.42 sounds like a great compromise for power and comfort on the highway. I'm hoping to have a rear wheel with a big offset to get as much rubber to the road as possible. I love the way your car looks with the Omni flairs but I'm trying to keep the stock look, no flairs. Anyway, the fronts may have to be a different size/offset/width. That leaves me with narrow choices due to availability of wheels that come in various sizes. The bolt pattern can be anything I want (according to Bobby V), but I'm going with a Lincoln 8.8 rear with discs so the pattern will be 5 by ?. The front will have to be changed to match. The next challenge is the rear and the gas tank. I'm hoping to avoid an expensive custom tank. Rob turned me on to a tank made by Todd Budde, but I don't know the pricing or availability yet. Any suggestions are appreciated. Let me know if you're around the 2nd wed of April, its the WDMGC meeting in Farmington Hills. Usually a good time and meet some more MG nuts. Any new mods on your B? TTYS Marc |
Marc
I may be around then I will let you know. As to my progress, well I had and still have a big list, I have been swamped and have had another project ahead of the B so I haven't even touched it yet. At least at this point I am not scrambling to get it back on the road as the weather gets nice (if it ever does) so when it does I will be ready to go for drive:) Joe |
Marc,
If you've decided on a 3.42 ratio for your 8.8, make sure it's available.....3.42 sounds like a GM ratio. |
3.27:1 should be an easy-to-find option too, I think.. That's what came in my '92 Mustang axle.
Here's a link to Dan Masters' handy Excel gear/speed calculator: [www.britishv8.org] |
Hey Rob ,
How much did that gas tank cost? Were you able to decide where your fittings were placed on the tank? The fittings in the picture at the MG experience looked to be facing the passenger side, just where the tail pipe will be going. Marc |
Graham,
I believe you are correct, I will have to decide between 3.27 and 3.55. Are you planning to come over for the WDMGC meeting next week? Marc |
Marc,
The missus and I will be vacationing and will miss the Detroit meeting but I'll be at the May WDMGC meeting in Windsor - hope to have the car operational by then! Using Dan's speed/gear calculator might sway you to use the 3.27 axle ratio. First gear is short enough and 3.55 will aggravate the situation - unless your T-5 has a 2.95 first vs the more common 3.35. |
