Cruise control unit
Anyone know if the AudioVox CCS100 is a good choice for cruise control? I know several people have used the AudioVox units & like them, but don't know if there's more than one version/model so don't know if that one is a good one.
There's a guy on the MGB Experience board who bought some from an auto parts store that's shutting down & he's selling them for $80 including shipping. Rob [www.mgexperience.net] |
Re: Cruise control unit
Rob,
That is the standard universal model. It is a good unit. Do a search on the main MG forum over there. I remember that the stock 4 banger MG guys have been using the CCS-100 for years. I see them going for $60-$95 on Ebay. I believe there is a model with a smaller actuator now. Some have an electric actuator. Sometime a vacuum reservoir can is needed for cars with big cams, just like for power brake boosters. I paid $25 for my NOS "antique" Sears cruise control. It was made by Rostra. I tucked the actuator can mostly into the fenderwell hole over near the washer fluid reservoir. [www.rostra.com] |
I installed the AudioVox CCS100 several years ago and it has worked great. I have the control switches mounted in the ash tray and raised them up about a 1/2 inch using a small block of wood. At the time (~2002) the AudioVox unit was the smallest, easy to hide and install.
I did discover that the AudioVox cruise control needs to detect a light bulb in the brake light circuit or it won't work. LED brake lights will not allow the cruise control to engage unless you add a resistor in parallel. Here is my web page on the installation [www.geocities.com] Edited 1 time(s). Last edit at 01/03/2009 04:44PM by v8mgb. |
MGB SS Wrote:
------------------------------------------------------- > How does this unit measure the MPH does it have a > magnet/weight on the driveshaft? > > Joe MPH is measured using engine RPM with a connection to the ignition coil. The cruise control kit also comes with a magnet and sensor for the drive shaft. I an using the tach/ignition coil method and it works great, fewer wires to deal with. |
I presume that measuring actual speed (at the driveshaft) is only advantageous on a car with an auto transmission. If you use the clutch to change gears the cruise control will automatically kick out anyway, right?
Moderator Wrote:
------------------------------------------------------- > I presume that measuring actual speed (at the > driveshaft) is only advantageous on a car with an > auto transmission. If you use the clutch to change > gears the cruise control will automatically kick > out anyway, right? Yes the only time you would want to use the drive shaft sensor is with an automatic trans. When the clutch is disengaged the control senses a sudden increase in enging RPM and releases the throttle. |
I'm guessing that if you had an automatic with a lock-up torque converter (like Steve's 700r4) then you might get by with the tach sensor? It might act a little flaky if you didn't have the lock-up engaged though.
The AudioVox CCS100 can also be connected to the VSS.
Mine is an older model cruise packaged for Sears. I used the driveshaft magnet. The clutch does not affect it since I didn't put a switch on it. |
MGB SS Joe Schafer Central Michigan (150 posts) Registered: 10/23/2007 06:46AM Main British Car: 1971 Mgb 1991 5.0 Ford |
If the only input came from the coil then it would only hold RPMs not mph and I assume you would only use it in a set gear example how would you go up a steep hill with an auto trans?
The VSS sensor is what I was hoping to hear. Joe |
