3.07
How do i change the 3.9 ratio MGB rear end to a 3.07.I have a 78 MGB with a Rover V8 and 5 speed.I bought an MGC 3.07 pumpkin to install.Any info will be appreciated.Thanks.Les.W4MGB
Re: 3.07
You can simply install the MGC differential complete...much easier than installing the MGC C&P into the MGB casing.
Be aware that the MGC differential most likely came from a wire-wheeled car (if sourced in the States) and will be narrower than your current MGB differential (assuming that you have a steel wheeled MGB) Have you verified that the MGC differential is indeed a 3.07. They were available in 3.07, 3.7, and 3.31 gearsets. There should be a stamping on the case...the gears are stamped as well. |
