mikejenelle
Mike White
(4 posts)
03/09/2008 09:50AM
5 lug x 4-3/4" bolt circle x 15 wheels for MGB
Posted by: mikejenelle
Date: December 15, 2009 08:23PM
I have opted to install a Fast Cars IFS and need to upgrade to a 15" wheel (Chevy/MGC 4.75 bolt pattern). I want to use a five lug but have not been able to locate anything? I've contacted over a dozen dealers with no luck. I need a 4.5" backspace or 22mm offset on the wheels. Any help would be appreciated. If you have a set to sell that is good - excellent condition please let me know. Also selling a brand new set of wheels with brand new 215/60 Cooper tires, mounted and balanced - zero miles on them. I bought them prior to going for the new IFS, they won't fit over the brakes. $750
Edited 1 time(s). Last edit at 12/15/2009 08:25PM by mikejenelle.
Re: 5 lug x 4-3/4" bolt circle x 15 wheels for MGB
Date: December 16, 2009 08:11PM
Mike, 15" 5x4 3/4 lug pattern are available from a bunch of places... for 4.5" backspace to be the same as +22mm offset, you'd have to be looking at 7" wheels (if I did the math right). Check the Shelby & Vintage styles here... [www.americanracing.com].
It'll be difficult to find that size in a recent OEM wheel, but shouldn't be too difficult in after market.
Good luck
Rob
J Man
jason adkins
NW OH
(202 posts)
01/21/2009 08:49PM
'61 Morris Minor panel, '70 MGB GT, '74 MGB GT MGB 1.8, unsure yet on the GTs
Posted by: J Man
Date: July 26, 2010 12:15PM
If you go with a billet wheel they can make just about anything you want in that pattern.
Date: July 26, 2010 04:46PM
Why do you have to use 4.75? Ted will do the IFS with any bolt pattern you want. With a +22 7" wheel, you'll have way more choices at 5x4.5 (5x114.3) &/or 5x100. I used 5x4.75 thinking chevy pattern wheels would be easy to find but then struggled to find 15" wheels in that patter & 0 offset that I liked. I ended up with wheels I really like a lot -- American Racing 427P's -- but they cost way more than I'd have had to spend otherwise.
danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Posted by: danmas
Date: July 26, 2010 05:32PM
I don't know if you like these or not, but they will fit on Ted's IFS
[www.billetspecialties.com]
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Posted by: mowog1
Date: July 29, 2010 10:55PM
Mike...
I would recommend a 16" wheel with the FastCars IFS. The clearance is sufficient for 15" wheels...but you REALLY need to watch where your tire weights are located. I have 15" Superlites on the GT.
If I were to buy wheels again, I would definitely go for the larger 16" diameter.
YOMV
bplus
Tracy Moore
Jacksonville, Fl
(40 posts)
11/24/2008 06:36PM
71' MGB GT 350 Chevrolet
Posted by: bplus
Date: July 31, 2010 10:19PM
I can't afford the the fast cars front end, but I do like the way my
16 x 8 front wheels fill up the front wheel wells. Summit racing
has stacks of 15" wheels to choose from, most with several
off sets to choose from, just my two cents.
J Man
jason adkins
NW OH
(202 posts)
01/21/2009 08:49PM
Posted by: J Man
Date: August 01, 2010 06:51PM
You are looking for one of the most common bolt patterns out there. Wether or not they make the wheel in the pattern you want will be the issue.
