MGBV8 project
I have started my ford V8 project for the B. Engine bay modifications done, modified crossmember installed, brakes tomorrow. Pictures when I download the camera.
Re: MGBV8 project
74MGBRoadster Brett Andrist Washington (state) (1 posts) Registered: 04/13/2011 11:50AM Main British Car: 1974 MGB Roadster Nissan SR20DET (hopefully) |
Re: MGBV8 project
Bill, the Journal section is a different part of the forums. It's basically a log with pictures and no replies can happen there. It's just for show and tell. Here's a link so we can watch and see: [forum.britishv8.org]
Re: MGBV8 project
Follow the link above then click on "new topic" . It's great because you can post up to 100 pictures and unlimited text to describe your progress.
Re: MGBV8 project
Bill, if the bleeder fitting and the inlet are not reversable then I think you have a problem, you'll never be able to bleed they system unless you use a reverse vacuum bleeder on it.
A hint as well, consider running a remote bleeder as well, makes bleeding using any system much easier as you can access the bleed screw and monitor the resevoir at the same time. I did on my car and it makes it a one man operation. Edited 1 time(s). Last edit at 04/21/2011 08:15AM by Bill Young. |
Re: MGBV8 project
I have exactly that same Nissan slave cyl on my conversion - bleeding in the normal way is not a problem.
Re: MGBV8 project
Bill, I really like the way you did your clutch slave cylinder bracket, wish I had done mine like that but now I'm too fat to crawl under the car to change it.
"P" |
Re: MGBV8 project
Paul, you look normal in your avitar. I have a two post lift outside my shop, so I can do underside work more easily. I am not too fat, but am getting too old to climb under. As soon as I get the model A ford that I am working on out of the shop, the B will go in and get the trial fit for the engine. I hope that is next week.
Re: MGBV8 project
Bill, That's cool, a Modle A and a B. What's next, a "C" ? lol. Nice work, roverman.
Re: MGBV8 project
Re: MGBV8 project
That looks great Bill, I used a 65 Mustang 6 cyl radiator but I don't care for the way it hangs down so low. May make some changes there but I like how you did the bulkheads on each side of yours.
Paul |
Re: MGBV8 project
I used angle iron to mount the radiator. I machined the angle of one side down on the bridgeport, so the combined width would just fit between the frame rails, and welded the angle iron to the frame. The angle is drilled and tapped to accept the radiator mounting bolts, and also the air deflectors, so I can remove them to service the horns, wiring, and hood latch. Almost time to pull the motor and do the cleaning and painting.
