Re: Wiper motor
Re: Wiper motor
That's mine. Here is a link to the maker:
[www.spwkits.com] They are probably the most comon aftermarket at the hot rod shows. I am putting a set in the Pantera too. If you look at the first photo Goeff posted, you can see I used the external assembly inside as well. It had the proper angle to tighten it all down. Mg wippers bolted right up. Gary |
Re: Wiper motor
What feature you like to add?
There are aftermarket electronic intermittent wiper modules that work with the stock wiper motor... I recall that JC Whitney used to advertise one. I thought the wiper motor and the fuel level sender were the only Lucas parts left on my car, but now I've discovered Lucas' name on the back-up lights and I'm fixing to put Lucas fuel injectors on my engine. |
