denvermgb Brad Carson Aurora, Colorado (104 posts) Registered: 03/10/2008 12:45AM Main British Car: 1975 MGB 350 SBC bored 0.040 over |
Rear brake caliper mounts
I am converting my Ford 7.5 rear diff to disks. I discovered today that the E-brake mechanism and spring hit the leaf spring. My questions: Is it OK to mount the left caliper on tthe right side (and vice versa) so the mechanism sits higher and over the leaf spring? I can't see why the caliper/brakes would have any negative impact just by mounting it upside down on each side?
Brad Edited 2 time(s). Last edit at 11/23/2012 04:13PM by denvermgb. |
Re: Rear brake caliper mounts
Brad, You won' be able to bleed them that way. The bleeder has to be up. Your axle must be a little narrower than most. Try them in front of the axle. Or flip the mounts around. I've seen a picture of Graham Crestwick's Mustang brakes on this site or MGExperience .
Edited 2 time(s). Last edit at 11/23/2012 05:40PM by mgb260. |
I just bolted the calipers on with the bleeder screws facing up as described. I used a small hose clamp to compress the E-brake spring flat and this helped make the room to get the caliper to bolt up. The E-brake spring makes contact with the leaf spring and I fear there won't be the required floating action of the caliper that is required. Any ideas?
Brad Edited 2 time(s). Last edit at 11/23/2012 07:38PM by denvermgb. |
Would probably work. What would happen if you traded the brackets side to side? You should put the rotors on also to make sure the caliper is centered. Graham , 7.5 is identical to 8.8 except for ring and pinion and larger housing. Same axles and bearings.
My rotors are at the shop to be drilled. The guy took the week off, so I have to wait 'til next week.
I will try moving the brackets again, but it didn't look like an option when I looked at that earlier today. I appreciate the input. Brad |
Brad, This link shows the brackets switched side for side,smooth side out. [www.ranger-forums.com]
I'll offer another option.......try lowering spacers to see if that gives sufficient caliper to spring clearance.
If that turns out OK and body height is not where you want it, then re-arched springs or RB springs should get chassis height back. |
Jim,
That link is the same set of directions I used. My car is a '75 so I have rubber bumber springs. I will look at the spacer option, too. Brad |
I did not want to mess with the ride height. We ended up rotating each bracket about an 1/8th turn and welding them on. This puts about an inch between the leaf spring and the bottom of the caliper.
I started tearing out the interior today (I can't finish the rear disk brake job until I get the rotors back from the shop and I build a mount for the Mustang E-brake lever on top of the tranny tunnnel). I am also welding in new floors. Next weekend, I will get the rotors on, do the brake line plumbing, take out the old floors/metal.... As always, thanks guys for your input. Brad |
