Moss Gas Tank
I’m on the verge of ordering a new gas tank for my GT from Moss, but before I do, I thought I’d get your opinion. Is the quality there and will the range be a significant problem? I have the ability and equipment to build a custom tank but I’m not sure with the amount of room I have in the original location it will be worth the amount of fabrication or I’ll gain that much capacity. What do you guys think?
Paul |
Re: Moss Gas Tank
I bought one about six weeks ago from Little British Car Co. for $157.00 plus shipping. Jeff Zorn is a great guy to deal with. Appears to be very good quality, made in Canada by Spectra. The sheet with the tank said that it didn't require paint and appears to be galvanized or zinc coated. I did degrease and paint mine though.
[www.lbcarco.com] |
Re: Moss Gas Tank
Moss offers tanks from two different manufacturers. You can read about the differences between them halfway down in this article: steel MGB fuel tanks. With a capacity of about 12.5 gallons, you'll likely have a cruising range of about 300 miles depending on your fuel efficiency. (In Palestine Texas my fuel efficiency was much less than normal, especially on the autocross day!) Some one gallon fuel cans will fit in a chrome bumper MGB's spare battery box, for a little reserve capacity. If you'd like more range, this is the easiest solution: aluminum 18 gallon MGB fuel tanks.
Re: Moss Gas Tank
I installed one of the Spectra tanks last Winter and I can say that the tank size is an exact duplicate of the original (10 Imp, 12 US). Some ads I've seen would lead one to believe it is 12 Imp (14.5 US) which is not correct.
There are no internal baffles, as original, and Spectra have discontinued selling the correct '75-'76 tank with the separate side fuel supply fitting and with the straight vertical filler neck. If you have a car from one of these years, you'll end up buying an pre '75 tank (with the angled fill neck) and using the correct year hose and metal fill pipe arrangement. In my case, since I had centred the fuel tank for dual exhaust, I ended up reworking the fill pipe to match the original. I've also had one issue with a slight fuel leakage at the side soldered supply fitting - corrected by gas tank repair putty. Overall, a well made tank for the money. |
Re: Moss Gas Tank
Quote: [www.mgenthusiast.com] |
Re: Moss Gas Tank
:) That is really BAFFLING ! Later models seem to have none from the Factory. Maybe Dot 4 fluid removes paint, but Dot 5 doesn't??? But the Racks can have either Grease or 90W gear lube. STRANGE???
Re: Moss Gas Tank
I’ve never removed a tank, is the roadster and GT the same? Do I just have to drill new bolt holes in the spare well and deal with the filler and fuel line to center it? Oh, I’ve been driving MG's for almost 45 years so I’ve had to walk on occasion thanks to the little darlings. I don’t know if the miles are longer in Texas, but it sure seems that way :-)
Thanks for all the info guys!! Paul Edited 1 time(s). Last edit at 11/18/2012 07:30AM by pspeaks. |
Re: Moss Gas Tank
Quote:Yes! ...and with some tank variation between years (fill necks, supply lines, vent fittings). Quote:In simplistic terms, yes! Typical shift is 3" to the left.and also requires some metal finishing on the trunk floor. Edited 1 time(s). Last edit at 11/18/2012 09:28AM by ex-tyke. |
Re: Moss Gas Tank
I don't have a trunk but I assume I will still have to modify the floor, what do I have to do to the floor?
Paul |
Re: Moss Gas Tank
Re: Moss Gas Tank
You may have noticed In the photo on my last post, that you can see the old and new mounting hardware in a couple of locations (3" shift).
Re: Moss Gas Tank
Yes, the picture is a great help and with your help I think I have it figured out now, thanks! My T-Bucket friends are trying to talk me into manufacturing a stainless tank with more capacity as we did for a couple of very thirsty buckets but they are all my age, retired, and tend to work for about ten minutes starting about noon then smoke cigars and drink Basil Hayden the rest of the day. I figure they would get done by next Christmas!!!
Paul |
Re: Moss Gas Tank
Wouldn't aluminum be easier?
Re: Moss Gas Tank
It would, and mine would be aluminum, but we did one for a customer out of stainless so that's their mind set. Aluminum wouldn't be as heavy either.
Paul |
Re: Moss Gas Tank
I found some railing end caps that work great for merging two curved bends. Don't know how big they make them but I will probably make a gas tank for my car and try to use those for the bottom four corners if I do. I know they are available, I just don't remember where I bought them.
