Sidewinder Cooling Fan
Has anyone used the Sidewinder Cooling Fan from Mattson's?
I'm needing more cfm in my car and I have NO SPACE. |
Re: Sidewinder Cooling Fan
PJ had one in his BGT and had to replace it in Townsend one year. Don' t know what he is running now.
Steve |
Which car Martin? If it's your 302 powered GT, I angled my radiator forward a bit at the bottom and was able to fit a Volvo fan. It kept temps under control in the TX heat this summer even with the AC on high & in stop & go traffic for over an hour. Don't recall if the Rover motors are longer than the Ford though?
How are you doing with your brakes.
lawnvett PJ Lenihan Winston-Salem, NC (477 posts) Registered: 04/29/2009 11:37AM Main British Car: 74 MGB-GT 3.4 V-6 crate, 5 spd |
I can send you the what's left of a broken sidewinder if you want to give it a try. the electric motor is ok, the fan & shroud is ok will need to fab the pulley and mounts. I think it was $4-500 new just pay the shipping. When installed pulley alignment was a problem.
Edited 1 time(s). Last edit at 09/24/2013 04:36PM by lawnvett. |
Thanks for the offer. I think I will continue to improve my current set up. I'm going to install a header tank system as a first step.
Cheers! |
