jim0899 James Willenbrink Florence, KY (60 posts) Registered: 10/05/2010 04:46PM Main British Car: 1978 MGB Chevrolet 327 |
Fuel filler tube
Just curious to find out if anyone has a good solution for rust the inside of the fuel filler tube on the MGB. I have a '78 and I havn't been able to locate a new filler tube, so I had mine bead blasted and powder coated (outside tube only) but I'm not sure what to use to keep the inside of the tube from rusting, that is also resistant to gasoline. Thanks
Edited 1 time(s). Last edit at 10/26/2013 09:39PM by jim0899. |
Re: Fuel filler tube
My suggestion would be electroless nickel plating. I chose that process for my EFI fuel rail, and I'm pleased with the results. The layer of nickel will adhere all through your tube, rather than mostly at the ends and along the outside because it's an auto-catalytic reaction and the chemical process is the same all throughout the plating tank. Regular anodic plating processes put a much thicker coating on the outside of the tube.
My local plating shop has a minimum order, and I think that's typical. You might want to wait until you have other parts to plate and do them all at the same time - because you'll probably end up paying a minimum fixed price for the whole shooting match. You can get a whole lot of small parts plated for the same price as just one part. If you decide to call around and talk to plating shops, make sure to ask them about your powder coating. I expect they'll want you to remove it. (electroless nickel plated fuel rail) |
Another alternative is Red coat liner they use in gas tanks. Radiator shops have it or you can buy online.
Edited 1 time(s). Last edit at 10/27/2013 12:35PM by mgb260. |
Thanks for the responses, since this needs to be put back soon sounds like the gas tank liner might be a good option for me.
Thanks again, Jim Willenbrink Florence, KY |
