4AGE Install
The Toyota twincam install into my 61 Midget has begun!
The shop is installing a "JDM" 4AGE 20 valve engine. The motor is the "Blacktop" version that comes equipped from the factory with Individual Throttle Bodies (ITBs) and is advertised by Toyota to produce 165hp. Transmission will be the Corolla GTS 5 speed "T-50" and the car will also be receiving a rear axle assy from the same GTS that includes an LSD diff. This should be a blast once it is finished. I dropped the car off this afternoon and the 1098 and trans was out of the car about three hours later! |
Re: 4AGE Install
Fellow crazies,
Well it as been two weeks and I am going to check on the progress and take pictures tomorrow. The blacktop 4AGE is supposedly at the shop getting mounts fabbed,,,,,,, |
Re: 4AGE Install
Thanks Brad,
I am really, really excited about this thing. My next project idea is to build a Lotus Elan S2 out of bits and use a Suzuki Hayabusa motor. Already located most everything I need. Jay |
denvermgb Brad Carson Aurora, Colorado (104 posts) Registered: 03/10/2008 12:45AM Main British Car: 1975 MGB 350 SBC bored 0.040 over |
Re: 4AGE Install
Let me know when you get the Midget running, I should be able to drive up in my 350 MGB very soon, a few minor issues to sort out.
Brad |
Edd Weninger Edd Weninger Mogollon Airpark Overgaard AZ (22 posts) Registered: 10/28/2007 12:49PM Main British Car: 1977 MGB Rover 3.5 L EFI |
Re: 4AGE Install
That is going to be pretty d**n cool. I had several spridgets in the day and they're fun cars even with warmed over 1275 cc.
Have fun...... |
Re: 4AGE Install
Will do Brad!
The 64 MGB is running pretty well now but its 2 feet in the air with all the suspension off so the spindles could be rebuilt and the whole thing re-assembled with poly bushings as mine were smashed. Also got a set of OE rear springs so the rear ride height won't look so ridiculous. Then, On the other side of the garage, The 69 Lotus Elan is up on ramps so I can install a full width aluminum "Griffin" radiator. Dug through the box, hmmmmm, no brackets! so it has been apart for 4 days while the local fabricator guy bends me up some nice side bracketry. This car is pretty quick for all stock but does not like this air when up in the mountains above Boulder and I am tired of pulling over waiting for it to cool back down. I beleive I am starting to test my wifes patience! |
