(6469 posts)
Best heater fan?
Date: December 07, 2013 06:15PM
What heater fan makes the best, easiest, and most airflow replacement for the stock fan?
lawnvett
PJ Lenihan
Winston-Salem, NC
(477 posts)
04/29/2009 11:37AM
74 MGB-GT 3.4 V-6 crate, 5 spd
Re: Best heater fan?
Posted by: lawnvett
Date: December 07, 2013 07:42PM
Fierro is a bolt in, the windscreen would demise twice as fast, and the unit cost is half of a new one from Moss.
(6469 posts)
Date: December 08, 2013 12:38AM
It's not a bolt in PJ, you have to cut the opening larger. There has to be something from a newer car with a powerful motor. Fiero is 30 year old tech.
(2463 posts)
Date: December 08, 2013 12:37PM
Here is a thread showing Graham Creswick's Hyundai heater fan conversion.
[www.mgexp.com]
(4512 posts)
Date: December 08, 2013 02:52PM
Yeah, it'd be a shame to mod the heater box. What would the purists think?! :D
(6469 posts)
Date: December 08, 2013 02:59PM
That looks really good, and being up north and knowing Graham I'd expect that to work really well. I sent him a PM asking if he'd found out what the donor vehicle was, some model of Hyundai. He also had hooked it up as a single speed, I wonder if he found that to be acceptable in the long run but didn't think to ask.
It does appear the hole had to be enlarged. Might be a "shame" to mod the box, but pulling and reinstalling the heater is not a joyful experience. We do need a mod that improves it without all that.
Edited 1 time(s). Last edit at 12/08/2013 03:02PM by BlownMGB-V8.
cruiseman
Richard Woodley
Ameliasburg, Ontario, Canada
(32 posts)
01/21/2010 02:51PM
1972 MGB GT Rover 3.5
Posted by: cruiseman
Date: December 16, 2013 11:51AM
I have the heater fan from a Hyundai Pony, mid 80's I think. You have to cut the box a bit, about 1/2 inch around but the fan is much stronger than the original and it's a two speed. I paid $10 at the wrecker.
I have attached two photo's, one showing the old fan and the Hyundai fan and the second shows the piece you need to cut out.
Richard
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
1975 MGB 350 SBC bored 0.040 over
Posted by: denvermgb
Date: December 16, 2013 09:50PM
I have Magnaflows right under each seat, gets the floor pan pretty warm! Not a blower fan, I know, but had to throw in my .02.
Brad
cgill
Chris Gill
Salmon Arm, British Columbia
(129 posts)
08/13/2009 12:06AM
1979 MGB roadster Buick 300 stroker with EFI
Posted by: cgill
Date: December 28, 2013 08:09PM
Jim, the guy doing the SBC swap on MGE is using a squirrel cage from a 2004 GTO. It's pretty big but it appears to fit with some serious trimming. I might give it a try with a spare heater box because I bet is really moves some air!
hirot
Ian Hart
Ashbourne UK
(88 posts)
06/01/2011 05:15AM
1971 MGB GT (conversion) Rover 3947 R380 gearbox
Posted by: hirot
Date: December 29, 2013 08:29AM
Whilst on the subject of heaters anybody know if you encounter problems mixing metal types as I wanted to make the connection between my heater....which is the larger one sold by Moss and may be hotter but the fan is useless....and engine in copper pipe so that I can put an air bleed valve in the top heater outlet.
Only ask as having lived on a boat I used to get a little twitchy when mixing metals in salty water because of corrosion and electrolosis.
Or am I better off having it made up in aluminium.
Ian
