1994 Mustang T5 in my B
I picked up a WC T5 tranny with bellhousing clutch and pressure plate for 5.0 conversion of my 1980 B. I now realize it came from a 94 Cobra instead of a fox body Mustang. The bellhousing is about 1 inches longer than a Fox Body bellhousing. Is this still going to work for me or will my shifter come out too far back? What about firewall clearance?
Re: 1994 Mustang T5 in my B
Keith, You are lucky you got the belhousing with it. 1" back isn't much. The popular T5 shifter has a dogleg in it to compensate. You may have to massage the tunnel a bit.
Edited 1 time(s). Last edit at 05/14/2014 04:04PM by mgb260. |
Depends where you mount the motor. I have a SN95 (94/95 5.0L) Mustang T5 and the shifter comes straight up through the stock hole. No offset shifter needed. And, the shift fork is rotated down a bit so there's more room for your clutch slave.
I used the same trans, but changed input shafts so that I could use the 87-93 bell. Either way, it will be fine if you build your mounts to suit.
I am using Bill Guzman's kit to mount the motor and tranny. I did a lot of measuring and some trial fitting of the bellhousing last night. After a little metal pounding and some judicious grinding of a few of the bellhousing ribs, it seemed to fit the trans tunnel nicely. I should get the refreshed tranny back Monday. Then I can put it all together, build my slave cylinder mount and linkage and sort out the hydraulic clutch line. Once those tasks are complete, i can actually drop the motor in and see if my setup works.
FYI Rob, your car is one of the cars that started me down this MGB V8 path. Edited 1 time(s). Last edit at 05/15/2014 08:54AM by Brownwood. |
RE: FYI Rob, your car is one of the cars that started me down this MGB V8 path.
I'll admit I still love hearing that. But considering I knew nothing when I started, it's proof anyone can do this if with the help and experience of this group! |
Quote: Not a chance! My wife wanted me to keep the stock engine in case I wanted to put it back. HA! Yeah, right. |
