1980 B: Fast Cars Radiator VS Sway bar
I trial fitted my Fast Cars 5.0 Ford radiator in my 1980 MGB today. I like the way it sits much higher than an early Mustang radiator. In fitting it, I realize that it occupies the same space as the front sway bar. It appears that no matter what radiator is used, the swaybar would be eliminated. I'm sure someone has solved this issue but I couldn't find anything in my searches.
Re: 1980 B: Fast Cars Radiator VS Sway bar
Keep looking through the photo gallery... there are a lot of photos!
The great majority of MGB V8 conversions have radiators shifted forward of their anti-sway bars. For one thing, that buys extra room for pulleys and "puller" cooling fans. My car is one of the few exceptions - I used a shorter radiator (specifically an AFCO "Sirocco style" radiator) mounted directly above the stock anti-sway bar position. That radiator works fine for me, but I'm not sure it would cool a 5.0 engine. |
I'd call Ted & see what he suggests. I don't know of a single Fast Cars build that came out of his shop without a sway bar.
I'll call Ted but I'm not using his front suspension. I have the radiator as far forward as it can go, about 1.5 inches forward of the stock location and right up against the grille panel, but no way will the swaybar clear the hose outlet without dropping it down more. I've already had to cut 3 inches off the bottom of the mounting brackets, losing one set of mounting holes, to get it to drop down far enough for the hood to close.
I have the same radiator and the fastcars IFS. I simply welded some blocks to the bottom of the frame rails and put captive nuts in them. If there aren't pics in my HIWD page I'd be happy to send you some.
Thanks Rob. Ill review your page and PM you if Im still in need. My radiator is completely different than any other Fast Cars radiator that I have found on this site....
Only difference I see is the top of yours is finished off nicely. Mine has the raw edges. I made a cap for it but never got around to polishing or installing it.
Rob, I found the pic of your swaybar spacer. Mine would have to be quite a bit thicker to work, about 2.5 inches, as the swaybar is about 3/4 of an inch shy of going over the top of the radiator outlet. A problem for another day...
If that is what it takes, it should be fine. I don't believe it will adversely affect anything by spacing down the sway bar 2.5 inches.
Spacing down the sway bar attachment to the frame has no effect on its function.
Edited 1 time(s). Last edit at 05/15/2014 09:29PM by JWD. |
Great, thanks all. Got a little frustrated but will address that issue when i get back from a weekend in Austin TX.
The Mantel solution is one even I can implement. Using a piece fo square tubing is simple brilliance. I just didnt know you could movea swaybar down with no ill effect. Freak Out terminated! Edited 1 time(s). Last edit at 05/15/2014 10:18PM by Brownwood. |
worn Warren Bond Toronto (26 posts) Registered: 06/28/2013 09:56AM Main British Car: 1973 MGB 305 Chevy |
