mindseye John Csuhany Edmonton, Alberta, Canada (76 posts) Registered: 11/18/2009 11:40AM Main British Car: 1980 MGB 1962 Buick 215 cu. in. |
Where did you get your Hood Scoops??
Well I wasn't going to do it but I am pulling so much air through the engine now that I chucked the old 2-1 exhaust I want to put a snazzy edelbrock air filter I found on my car but I will have to cut a hole in the hood. seen some really great scoops on this forum but where did you get them?...I am especially interested in the rear facing ones cause 1-the low pressure area pulls more air in and 2-it will be better for keeping the rain out and 3-they look cool... I am especially interested in the bolt on ones since I really don't want to do a hell of alot of bodywork if I can help it, Thnx. for all replies.
Simon Austin Simon Austin Surrey, British Columbia (107 posts) Registered: 10/23/2007 01:44AM Main British Car: 1977 MGB V8 / 1970 MGB GT V8 project Rover 3.5 / Rover 3.5 |
Re: Where did you get your Hood Scoops??
made mine - sculpting clay on the hood for the shape - took a mold, ditched the clay and pulled a fiberglass part.
Tom,
I been toying with just that for years. I want one similar to the RV8 that can cover a 14" air cleaner. Before I go off Googling, do you happen to have any good web links that detail how to go about making a fiberglass mold? |
I did what Tom Lay did. It is a lot of work but I got just what i wanted.
Weird - Just yesterday afternoon I went out to the garage to to put some stuff in the extra refrigerator (more beer) - noticed some dust on the hood of the "red hot chili pepper" - I'm hanging onto the open refrigerator in a trance staring across the fender at the hood - I finally close the door and still in a trance (frankensteinish) make my way over to the front of the car - rather than cleaning the dust off, it was the perfect canvas for me to use my index finger and draw a very irregular austin-healey type hood scoop with the option of louvers adjacent to it - in my mind, it was a work of art - so, the moral of this little ramble is - you can always start with dust, and work up to clay!
Sorry, under the influence of cold and to much snow. |
Quote: Hmmm... I suppose you've seen this "How It Was Done": [www.britishv8.org] |
I am pretty partial to this one, local guy sellin it with a 350 chev in it....the scoop is from race composites, a camaro scoop but smaller....looks pretty cool....I keep hedging between going for look or function, I drive it anytime & can just see the hassle with rain I will get using a scoop, some of you guys got great looking scoops and probably need em with the induction height but I can just close my hood on a low profile 14" cleaner.....ahh.. to relieve the adolescent dreams, I have already made concession to a dual exhaust with cherry bombs now I have to crank my stereo louder but I sure get double takes when I roar past folks.
jimbb88 Jim Stuart Maryland, USA (47 posts) Registered: 10/23/2007 07:43PM Main British Car: 1966 MGB V8 conversion Rover 4.0 fuel injected |
RV8 Hood(bonnet?) from Adrian in OZ. One of the V6 guys just did a new web site and he has RV8 copies at a very reasonable price. BMC maybe?
This is not a scoop, just a bulge, but it is very tastefull, subtle, like my yellow GT, and may give you the room you need. |
Hrh Jim...checked out your car on the pics forum...very nice...I do like the bump definetly more subtle and rain proof....I sent in my pics for the forum but the moderator hasn't put em up??? ...Mr. Moderator?
1) Curtis - looked okay on the hood but......seeing on the car......imho it would have been more subtle to follow the lines of the hood and taper it in (per A-H) without cowl - although that most likely wouldn't have gotten him the clearance he needed for intake/cleaner.
2) Yikes (louvers on black car)! 3) Can't go wrong with the RV8. |
Thanks Jim, Yes we have the RV8 bonnet plus a little more. It may be hard to tell but these have slightly more room than the standard RV8 but it has been done in good taste and unless you had the original next to an improved copy, I believe you would be hard pressed to see the difference.
Here is the direct link: [bmcautos.com] My pictures need work and I have had no time but here is an attempt within the last few days to update. We have a nice primer grey BGTV6 that is going through a partial restoration and modification that needed some pictures. -BMC. Edited 1 time(s). Last edit at 01/19/2010 12:37AM by BMC. |
Hi Brian,
"Yes we have the RV8 bonnet plus a little more. It may be hard to tell but these have slightly more room than the standard RV8" Does that mean my 14" air cleaner will fit under it? That's what I have been wishing for a long time, an RV8 hood bulge that will provide clearance for an Edelbrock intake/carb/14" air cleaner. |
Carl, how much taller is the Edelbrock vs. the stock Buick 4bbl? I got the stocker under the stock hood with a good bit to spare on my old gray 1977. I used an extreme low rider by Federal Mogal that D & D used to sell. The last ones I saw from them did not drop as much as the old one.
Jim,
I don't have one yet to measure, but I have had 3/4" taller in my head for a long time. I would also prefer to use a 3" tall air filter. There's not much room above the carb inside the air cleaner. |
