MGB Driveshaft seems too close...
So I got my driveshaft in the car today. It seems dangerously close to that cone shaped thingy at the rear of the body near the diff. I only have about 1/8th clearance between the front edge of the cone and the driveshaft. Seems like a good bump and the two could kiss. Any reason this cant be cut out as long as the parking brake mounts remain?. I dont see what purpose it serves.
mstemp Mike Stemp Calgary, Canada (222 posts) Registered: 11/25/2009 07:18AM Main British Car: 1980 MGB Rover 4.6L |
Re: MGB Driveshaft seems too close...
Two functions. 1) Structure. 2) Hold up driveshaft should u joint fail etc. so you don't go pole vaulting!
You wouldn't be the first here to replace that brace with a deeper-section substitute. In fact, MG went from a shallow brace on chrome-bumper MGBs to a deeper brace on rubber-bumper MGBs.
Example: Terry Schulte's GT Before you do that though, you might want to double check pinion angle. Wedge shaped shims installed between leafsprings and axle are often used to adjust the pinion angle one way or the other. If you can make the angles work out, those wedges might buy you a little clearance. |
Thanks for the info. I didnt realize it was a structural component. I am surpirsed since my car is an RB car but ther have been many surprises in this build. Ill definitely look at the pinion angle.
OK, it looks like I can remove abut 1/3rd off the front of that cone and then I will have plenty of clearance. Its just the very front where I have an issue. If the picture above with the tube welded in is strong enough then I should be fine as I will have a lot more of the cone left than the amount of steel that tube represents.
Keith, are you looking at that clearance with the car on the ground or in the air?
Remember that the drive shaft will rise into the tunnel when the car is on it's wheels. Cheers Fred |
Fred, I actually had a jack under the diff so it was at its highest point in the car. That's what made me nervous. ON the ground the diff actually rubs the front of the cone and I cant get the tranny any higher. Whats also weird is that this car has lowering blocks on it so the diff is 1 inch higher in the car than stock. If I left off the blocks it wouldn't have fit at all.
Keith,
I'm inclined to suspect some fundamental installation issue with the axle - a lot of us have done axle and driveline installations without having to touch that structural piece. Have a good look at how things are put together and check driveline angles between bump and rebound before you commit to removing any sheetmetal. |
OK, Ill check but it would have to be significant. I have the motor as low as it will go in the front and the trans as high as it can go in the back. Not exactly sure what to look for?
With the car sitting on the ground (it has a 2.5 inch rake front to back) the diff looks pretty level with the ground. Also, how much clearance is acceptable. I would think at least 1/2 inch at the front of the cone? I have about 1/8th. Edited 2 time(s). Last edit at 07/19/2014 09:02AM by Brownwood. |
For curiosity's sake, I just measured my driveshaft clearance to that structural component at 2-1/4" at the rear and 1-1/4" at the front
This axle happens to be a Ford 8.8 with a pinion up angle of about 3 degrees, but most axle installations will be similar. Crappy photo attached....... How about posting some photos of your axle instal. - maybe some of us can point to a potential problem area. Edited 1 time(s). Last edit at 07/19/2014 10:19AM by ex-tyke. |
Keith. appears the ford engine /tranny is mated to the OEM MGB R/E. Your engine/Tranny is probably not sitting at correct angle for the MGB R/E. Originally I used the MGB R/E and it lived awhile. After installed the Ford 8.8 dif, the u-joints in the adapter shaft were shot. The angles were off badly and caused the failure. When we added the 8.8, we welded the brackets on the R/E housing to attain the correct pinion angle. no problems after 40+k miles. my 2 cents worth.
As Kelly mentions, you need to check the basic engine/xsmn power angle......it's possible that the xsmn mount needs to be raised.
OK, I got the rear trans raised to get 2 degrees angle at the engine. Pretty sure the bellhousing is right against the trans tunnel though.
I now have about 3/4 inch at the front of the cone and 2 1/4 at the rear. Still seems a little tight. I honestly wish I had gone another way with this, like a V6. I got sucked in with the fact that there was a kit and that this car had a factory V8 option in Britain. I had no idea the entire car had to be reingineered! I'm sure it will be awesome when completed though ! Edited 3 time(s). Last edit at 07/21/2014 10:21AM by Brownwood. |
Keith, don't throw in the towel just yet! Let's see what you've got:
Your engine mounts are presumably fixed, so raising the xsmn mount is the only variable to allow increased propshaft clearance - try to get as much height as makes you feel comfortable without bellhousing interference. (make sure it is the bellhousing and not the top of the T5 xsmn that is hitting - reason I mention is that it is routine to provide xsmn clearance for most swaps by providing 3/8" clearance at the dash panel/tunnel interface by using a BFH) Now you should test the degree of driveline interference in the axle rebound condition (assuming that the MG original rebound straps are mounted) - support the body under the sills and slowly lower the RA to check. Let's see how much, if any , interference exists, now..... Don't worry about matching the power angle to the RA angle just yet |
quote: "I honestly wish I had gone another way with this..."
Think about how much progress you've made since January when you first registered and started asking questions. People spend years getting as far. You'll get this clearance issue resolved soon enough. From my perspective, it looks like you're doing great. |
Hey Curtis you are right! It was kind of a let down because I thought the car might go mobile by next weekend, not driving ready but mobile! This is a much bigger project than I expected. Probably had a wee bit too much confidence since I have done numerous engine swaps before. Anyway, it is coming along, just got a little frustrated. This project has pushed my skills and that's not a bad thing. Might just need to take a break for a few days as Ive been working several hours a day and all weekend since the 4th.
Graham, you are right, I am getting some contact with the tranny just in front of the radio and heater control mount. It looks like a beast to get in there and cut a hole from inside the car but that looks like the next thing I need to attempt. I originally said to myself that if I was going to do one car, it had to be a V8! Need to remember that. Endeavoring to persevere :) Edited 1 time(s). Last edit at 07/19/2014 09:44PM by Brownwood. |
Quote: Hammering a flat at the offending location is more desirable than cutting sheetmetal. |
Well, a SBF is not the easiest, but it's not that bad. Plus, it is more rewarding than most swaps. You are almost there, so hang tough as Telsa would say!
[www.youtube.com]) |
