harv8
Martyn Harvey
Waterloo, Ontario, Canada
(189 posts)
10/23/2007 10:09PM
MGB Rover V8, TVR Chevy V8, MGB GT Ford V8
Heater Core Leaking
Posted by: harv8
Date: August 07, 2014 01:46AM
Enjoying the GT this summer but ...... been off the road with a couple of annoying issues lately:
a) last month.......burned up alternator after only 1700 miles from new...........rebuilt it but why did it burn out?
b) this week..........coolant dripping from under the car with no evidence of a leak in the engine bay or rad........
I suspect the heater core is leaking and the coolant is dripping out the drain hole in the heater well. There is evidence of coolant in the footwell heater outlets but none is dripping into the interior.
Did I cause a leak by using a 20psi rad cap? Perhaps the core just got old and started to leak?
I'm not looking forward to removing it :(
Is there some kind of an "upgraded core" that I should use or do I simply replace it with an old spare one I have in my parts bin?......after making sure it is in good condition, of course.
(1367 posts)
Re: Heater Core Leaking
Date: August 07, 2014 11:54AM
Martyn,
To answer your question. The alternator burned up because nothing was leaking. Now that the heater core has failed the alternator will be just fine.
20 psi is considerably more than the heater core was designed for. But it should hold up well if it's in good condition.
If you're using an old core. Take it to a rad shop and have it cleaned and pressure checked. Make sure that they are aware of your system pressure.
If you use a new one, make sure that is a copper construction and not the plastic tanked variety.
Or just have the rad shop recore your old one with a heavy duty core.
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Posted by: harv8
Date: August 07, 2014 04:33PM
"The alternator burned up because nothing was leaking. Now that the heater core has failed the alternator will be just fine."
.....yes, of course :)
Thanks Fred!
robert1839
Tristan Cook
5579 Timber Ridge Dr, Mt Vernon, Skagit, Washingto
(118 posts)
05/06/2013 11:11PM
MGB GT 1972 Buick 215
Posted by: robert1839
Date: August 09, 2014 11:44PM
was it a lucus alternator? i have never had a lucus alternator go vary long end up replacing it twice a year. we ened up putting the alternator out of another car, i dont recall witch one at the moment, and rewiring it and that has lasted years that way
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Posted by: harv8
Date: August 10, 2014 11:51PM
Heater core is out
hirot
Ian Hart
Ashbourne UK
(88 posts)
06/01/2011 05:15AM
1971 MGB GT (conversion) Rover 3947 R380 gearbox
Posted by: hirot
Date: August 11, 2014 08:09AM
Martyn, don't know if it is important but the inlet/outlet pipes of the heater core shown don't look like they fit the holes on the front panel of the heater box. The core shown looks like an 1800cc core and the panel looks like a UK Rover V8 panel i.e. inlet and outlet about 4" different in height.
My radiator cap is 15lbs, so 21 lbs might have found a pinprick hole....which would have been found out by a lesser cap a bit later.
Enjoy.....Regards Ian
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Posted by: harv8
Date: August 12, 2014 08:36AM
Good news bad news.
Heater core testing good showing no evidence of any leaking. So it looks like the hose was leaking?.......even though there was no coolant in the engine bay. Well....actually there was some coolant laying around the bottom of the heater box but the vast majority was inside the heater box. The hoses were tight too. I'm rather confused.....I suppose the coolant could leak from the top hose and run back or be forced into the heater box and drip down the core.
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: August 12, 2014 10:21AM
Martin,
I saw a youTube from John Twist where he states that it is very rare to find a B heater core that leaks. He says that it's usually the hoses that leak, FYI.
Scott
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Posted by: harv8
Date: August 14, 2014 10:15AM
It was the hose....all is good now :)
I guess I am happy that (once again) I learned a lot from this adventure!
Capt'n Moorgone
Mike Moor
Angola,IN
(116 posts)
11/20/2008 07:05PM
1973 MGB 300 Buick
Posted by: Capt'n Moorgone
Date: August 14, 2014 05:57PM
Martyn, are you going to make it to Twists' show this weekend? Hope to see everyone there! Mike
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Posted by: mowog1
Date: August 14, 2014 07:19PM
I'm driving up on Saturday...will see you Spuriites sometime between 1030 and noon at the showfield....camping out at Carricks that night....home on Sunday.
harv8
Martyn Harvey
(189 posts)
10/23/2007 10:09PM
Posted by: harv8
Date: August 14, 2014 10:57PM
Won't be at Twists........I'm sure you will all have a great time around so many awesome cars and MG people :)
Carol and I are booked in the Talley Ho for the October Meet in Townsend......hope to see everyone there.
(4516 posts)
Date: August 15, 2014 09:27AM
Great!
