mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
rover automatic to T5
Posted by: mowog1
Date: December 04, 2014 12:27PM
Question.....A friend of mine is about to sell a Rover V8 from a Discovery that was originally an automatic.
If someone wanted to fit a T5 does he need a Rover manual bell housing....or will he need to obtain a BOP bellhousing (or an aftermarket such as available from D&D???
(I'm not sure of the bolt pattern of the Rover automatic to bell house)
Thanks in advance.
Re: rover automatic to T5
Date: December 04, 2014 02:29PM
The D$D bellhousing should do the trick.
avbates
Tony Bates
San Jose California
(25 posts)
03/22/2008 12:16PM
74 MGB roadster 4.2 litre Rover
Posted by: avbates
Date: December 07, 2014 08:26PM
Yep, the D+D one is what I used with my 4.2
Date: December 12, 2014 11:48AM
There "is" 215 Buick/Olds, if you can find.. Make sure it's the large hole/ big 4 speed bolt pattern. Small hole/pattern fits the early 3 speeds. Good Luck, roverman.
britcars
Phil Ossinger
New Brunswick, Canada
(346 posts)
02/02/2009 07:58PM
1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA!
Posted by: britcars
Date: December 12, 2014 01:48PM
I stumbled across a three speed bolt pattern (big hole) BOP bell housing cheap and TIG welded some rough shaped aluminum billet in place then surfaced it in a vertical mill, drilled the 4 speed pattern and installed Timeserts. Might be prohibitively expensive unless you have access to the right tools.
