Rebuilt 1994 WC T-5 slight fluid leak
Sigh....just got my 93-95 GM 3.4 V6 engine and T-5 installed in my 1969 along with a new 18 gal aluminum gas tank plus all the new wiring and plumbing.
I had the car taken over to an exhaust shop this morning for a new system and when I get it back home I plan on starting it for the first time. While on the hoist at the shop I noticed a small drip forming on underside right where the gearbox mates with the extension housing. Should i be worried? The guy that did the transmission rebuild had good reputation, should I try gently to see if I can tighten the bolts a little more or is that now a lost cause. I really don't want to have to pull the whole set up back out again. I filled the transmission through the shifter opening and at the 3 quart mark there was nothing coming out of the level hole. |
Re: Rebuilt 1994 WC T-5 slight fluid leak
Is there any possibility of spillage when you filled it?
It may have just followed the seam down to the bottom of the trans. |
Lots of us run close to 3 quarts without issue. Once upon a time there was a GM service bulletin that instructed techs to add more fluid.
Yep.
The official fill level is 2.8 quarts according to my gm info. |
FLIPSMGV8 Phillip Quinn Reidville, SC (15 posts) Registered: 04/21/2010 10:01PM Main British Car: 1978 MGB Rover 3.9 V8 |
My T5 trans took just about 3 quarts before it started to run out the fill hole but my tranny is not a WC. I have only put a few hundred miles on it and as of now it seems to be ok. I'm still working out a few bugs but she sure runs better with this engine than I expected. Michael when you get her going it's going to be about more fun than one should have.
Phillip, thanks for the encouragement, I need it with all the problems I am experiencing, see my other posts. At least the engine seems sound, 75 psi oil pressure at start in 80 degree weather, dropping down to around 70 when engine is hot.
I noticed your post about the HTOB. Did that HTOB require the shaft collar to be replaced? If so, it's quite possible that your leak is coming from there. I have an HTOB and have been battling a leak in that area. Just a thought.
