limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
93-95 GM 3.4 OHV tach signal strength?
Posted by: limey222
Date: September 10, 2015 05:10AM
can anyone tell me what is the correct signal strength for the tach signal coming out of a standard PCM for this engine?
I assume it can be measured on a volt meter set to AC. Mine seems too low for even a Dakota Digital black box to amplify high enough to activate a VDO tach.
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Re: 93-95 GM 3.4 OHV tach signal strength?
Posted by: Scott68B
Date: September 10, 2015 06:53AM
I believe it is a 5 volt square wave.
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Posted by: Charles
Date: September 10, 2015 09:22PM
I have VDO gauges, so when I tried to use the output from the coil pack I could only get 0.4 Volts. The guys at VDO said 4.0 V was min. I now use one of the phases from the alternator. Vdo has the setup to use the alternator. I have 3.4l V6 GM.
limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
Posted by: limey222
Date: September 11, 2015 04:56AM
my PCM tach feed in the BMC harness is only putting out 0.35 volts so i will have to go with the aleternator signal route.
