Buick 300 heads on a 215?
Hi! I'm new to the list but not to the hobby. I put a 215 into a 1978 MGB some years ago and am now redoing the whole project...picked up a set of of 64 Buick 300 heads years ago and am now wondering about bolting them onto the 215 block. I am aware that the larger combustion chamber size in the 300 heads will lead to a lessened CR but some seat-of-the-pants calculations indicate that using stock 215ci 10.25:1 pistons with these 300 heads would result in a final CR of about 9:1. Does anyone know if that is an accurate guess-timate? Has anyone out there done this? Those 300 ports are much bigger the the 215 ports as are the valves...a very tempting substitution at first glance.
Re: Buick 300 heads on a 215?
I used 300 heads years ago on a 215. I used the hi compression pistons, and 8.5 to 9 to 1 is about right. You could use a compression calculator and figure 39 cc for 215 chamber vs 54 cc for the 300. .020 for steel shim vs .040 for composition head gasket. I would deck the block .030 and skim the heads to make sure they are flat to regain some compression. Here is a compression calculator:
[www.csgnetwork.com] Edited 1 time(s). Last edit at 02/13/2016 03:03PM by mgb260. |
