W4MGB
Les Biglands
(4 posts)
03/04/2009 02:31PM
3.07
Posted by: W4MGB
Date: February 07, 2010 03:14PM
How do i change the 3.9 ratio MGB rear end to a 3.07.I have a 78 MGB with a Rover V8 and 5 speed.I bought an MGC 3.07 pumpkin to install.Any info will be appreciated.Thanks.Les.W4MGB
(2463 posts)
Re: 3.07
Date: February 07, 2010 04:12PM
If I recall correctly you have to machine .215 off MGB case for 3.07 gear to fit or use the MGC case?
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
1974.5 MGB/GT 3.9l Rover
Re: 3.07
Posted by: mowog1
Date: February 07, 2010 04:52PM
You can simply install the MGC differential complete...much easier than installing the MGC C&P into the MGB casing.
Be aware that the MGC differential most likely came from a wire-wheeled car (if sourced in the States) and will be narrower than your current MGB differential (assuming that you have a steel wheeled MGB)
Have you verified that the MGC differential is indeed a 3.07. They were available in 3.07, 3.7, and 3.31 gearsets.
There should be a stamping on the case...the gears are stamped as well.
W4MGB
Les Biglands
(4 posts)
03/04/2009 02:31PM
Re: 3.07
Posted by: W4MGB
Date: February 08, 2010 07:35AM
The numbers are 501 14 43.Thanks.Les.
mowog1
Rick Ingram
Central Illinois
(1523 posts)
10/17/2007 09:36PM
Re: 3.07
Posted by: mowog1
Date: February 08, 2010 10:32AM
43/14 = 3.07
