Ford 5.0 and T5 clutch actuation
I think I am about 6 weeks away from pulling the original engine and tranny and starting my 5.0 Ford and T5 swap in my 1980 MGB.
I am still struggling a little with clutch "linkage". Is this the way to go for a slave cylinder system? [www.novak-adapt.com] |
Re: Ford 5.0 and T5 clutch actuation
I think the photos in this article do a particularly good job illustrating clearance issues for the MGB/SBF/T5 combination, and how a Nissan truck pull-type slave (like Graham's) helps to solve them: [www.britishv8.org]
Keith,
Here's a typical ebay auction for the Nissan clutch slave...Readily available from Rockauto or any major auto parts store. [www.ebay.com] |
Addicted Mike Hagadorn Warren PA (132 posts) Registered: 09/27/2013 03:46PM Main British Car: 1976 TR7 Victory Edition Ford 302 |
That Nissan setup is a push cylinder, just to avoid confusion (probably obvious). I did something similar, but of course I made it much more complicated and painful than it needed to be. I'm good at that.
Push cylinder does package much tighter than a pull setup. Graham, Is that your setup? What are you attached to other than the tab below the reverse lamp switch? Edited 1 time(s). Last edit at 03/24/2014 02:51PM by Addicted. |
Very nice. I decided against that slave cylinder because the bleed fitting was on the bottom, but I should have went with it. Much cleaner. My setup works very well, but the bracket is much crazier.
Quote: True...but it actually bleeds very well. |
My kids, more often than not tell me I'm wrong about everything, so I thought I'd ask. I was told that the actuation rod should be adjusted so the throw out bearing rides against the pressure plate. Is this correct? I had planned to use a return spring like Graham but was told, by the same people, that with the bearing against the plate I didn't need a spring. Being an "Old School" kind of guy I'm a little uncomfortable with that, but as I said, I'm often wrong. What do you think?
Paul |
I'm not sure but I believe it's dependant on the bearing you're using. The one I got did say it was designed to be stay in contact with the plate. I'm going off memory, but I belive it said 4-5lbs of pressure. I don't have a way to measure that so I just adjusted mine to be in light contact. 4.5k miles so could prove to be wrong still, but so far seems to be working fine.
Quote: The Ford release bearing is of the "constant running" variety and is installed with a 4# pressure against the clutch fingers -( no bearing to diaphragm clearance required) My return spring is installed just for assurance that the whole linkage remains in contact (but in theory not required) |
Great question, and I'm glad to see the answers you guys have offered. My To-Do list has "Decide about return spring for TOB".
Other than wear, I've also seen comments on noise. If it sounds OK, I'll go without one. I used a "Perfection" clutch kit (nothing fancy). |
If it was me I'd use Paul's linkage and Graham's bracket for the perfect setup.
The return spring is more of a personal preference thing. Pretty much every throw out bearing available these days is capable of "constant contact" use. The deciding factor is your slave cylinder. Most newer designs have an internal spring in them to force the piston out. This takes up all of the linkage clearance and gives you a constant contact system. The advantage is no more clutch adjustments and no pedal free play. The clutch feels much more direct and with no free play the leverage can be increased slightly for a softer pedal. The down side is a minor acceleration of clutch finger and throwout bearing wear. As well as wear to the clutch arm from the constant movement. For slaves without the internal spring your only option is the return spring with an adjustable link for free play. Setting this type of slave up for 0 clearance is an invitation for disaster. It's called an interference fit. Because when it goes wrong it interferes with your bank account. The advantage is longer component life. The down side is regular clutch adjustments and the loss of movement due to the necessary pedal free play. That probably just muddied up the water. But you know, I gotta say something. Cheers Fred |
What are the Pro's and Con's of the CNC not having an internal spring considering an external spring is used? Obviously the external spring keeps the return pressure on the rod so the piston can't retract and the rod fall out. I assume the internal spring pushes the piston back as well???
Paul Edited 1 time(s). Last edit at 04/08/2014 11:43AM by pspeaks. |
Internal spring pushes the cylinder out, so it does the opposite of a return spring. It make sure the system doesn't go slack, where the external return spring makes sure the sytem does go slack (if it's adjusted with slack in it).
