BWA
(344 posts)
04/13/2010 08:13PM
Information Needed ON MGB Gas Pedal
Posted by: BWA
Date: July 20, 2017 12:29AM
I installed a GM 3400 in a TR6 and I have to rejig the gas pedal due to other issues.
I have been made aware that the stock MGB gas pedal works with the cam on the throttle body of these engines.
I am modifying the TR6 gas pedal to work the same way but I need the following information to make the arm the right length:
Can someone give me this dimension?
Someone must have one of these kicking around without trying to squeeze under the dash to measure it.
I have tried to scale it off of pictures on the internet but it is just guess work.
Thanks for your time and consideration.
Byron
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Information Needed ON MGB Gas Pedal
Posted by: ex-tyke
Date: July 20, 2017 05:53PM
That dimension is as close to 4.0" as I can measure (in situ).
pspeaks
Paul Speaks
Dallas, Texas
(698 posts)
07/20/2009 06:40PM
1972 MGB-GT 1979 Ford 302
Posted by: pspeaks
Date: July 22, 2017 05:39PM
Hey Byron,
I happen to have an uninstalled/unmodified 1972 MGB "Go Fast" pedal hanging on the wall in my shop. Don't know if they are all the same, others may differ, but the one I have is 4-1/8" from the center of the mount hole to the spot where the cable goes through at the end. Hope that helps, good luck with your mod.
Paul
Edited 2 time(s). Last edit at 07/23/2017 01:18AM by pspeaks.
