Question about Quaife installation in MGC
So in the case of fitting an MGB with a Quaife do the shims still go between the bearing and the housing or between the bearing and the carrier ?
Re: Question about Quaife installation in MGC
Better put them on the diff. If you put them under the caps they can squish out, and then you've ruined your gears. BT.
