louebird Louis Realmuto Long Island, NY (3 posts) Registered: 12/21/2017 12:40PM Main British Car: 1980MGB 3.9 Rover |
Torque specs for MGC drive shaft flange?
I'm replacing the original 3.90 rear end in my 1980 MGB with a 3.30 MGC unit. The original 'C' flange is slightly larger and has a different bolt pattern. After installing the 'B' flange on the 'C' housing, what is the correct amount of torque used on the flange nut?
I've been told that the 'C' units use a regular spacer as opposed to the collapsable washer used in the 'B' units. There is plenty of info out there for the 'B' rear ends but I can not find anything pertaining to 'C'. Any information would be greatly appreciated. Thank you, Lou |
Re: Torque specs for MGC drive shaft flange?
I've seen a 135-140 spec and a 90 spec (Glen). If you have a crush spacer you might start out at about 80 and go in 5 or 10 lb increments, checking to be sure the pinion bearings haven't tightened up any. If not and you get to 140 I'd stop there. If they do, stop immediately, back off and torque to the next lower increment and check again. Hopefully at that point your preload will be within reason.
Use a sealant on the spline and loctite on the threads. Jim |
Jim, Thank you for the response. The question now is "do C rears use crush or just a regular spacers?" I'm getting conflicting information and I don't have a MGC manual because I've never owned an MGC.
Thanks again, Lou |
